Farm Pro Diesel Tractor will not start
   / Farm Pro Diesel Tractor will not start #1
DaveBlock
Louisville, KY
FarmPro 2425
My Farm Pro diesel tractor started first time after winter and ran for 5 minutes. It will not start again. It turns over but seems like it is not getting fuel. I replaced the fuel filter, air filter, and put fresh diesel in with no luck.
   / Farm Pro Diesel Tractor will not start #2
Check the tank outlet strainer and the inlet line to the filter and the filter connection for restriction. Make sure the fuel solenoid valve, if you have one, is opening when key is on
   / Farm Pro Diesel Tractor will not start #3
Like he said, mine disintegrated mid way thru the winter while I was plowing, started off as a slight miss and after 10 minutes started getting worse till it finally stalled. It would start right up but not keep running, the strainer in the tank was covered in what looked like plastic sludge, the strainer had melted and plugged off the fuel line.....Mike
2004 INTERNATIONAL DURASTAR 4300 (A50854)
2004 INTERNATIONAL...
2005 Ford F-550 Bucket Truck, VIN # 1FDAF56P45EB88239 (A48836)
2005 Ford F-550...
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
2015 FREIGHTLINER CA125SLP SLEEPER (A51219)
2015 FREIGHTLINER...
2007 NISSAN ARMADA (A50854)
2007 NISSAN ARMADA...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A49461)
2007 Bomag...
