Farmall 50A, 60A, 70A Wheel Spacers
   / Farmall 50A, 60A, 70A Wheel Spacers #1
klancf51
PA
CASE IH, Massey Ferguson, Ford
I need to add wheel space for a Farmall 70A with 4WD. Case IH doesn't carry wheel spacers for these Farmall A utility tractors, so I will have to have them made, and accurate wheel dimensions are required. I measured the rear wheel pattern for the 14.9-28 R1 wheel plate: 8x203.2 mm bolt circle with 152 mm wheel center bore, M16x1.5 threaded studs. The fasteners are M16x1.5 flange wheel nuts. As it turns out, this ag wheel pattern (8x8" bolt circle, 6" bore) is not uncommon, so I am confident in the rear wheel dimensions.
The front wheel pattern is a bit more difficult because of the hub for the MFD. The fasteners are six M16x1.5x35 mm hex cap screws, Gr 8.8, full thread, Zinc Chromate finish; requiring flat washers (16.4mm ID x 28 mm OD x 3 mm Thickness, Gr 8.8, Zinc Chromate finish). That's about all I am certain of. Does anyone know, for certain, the front wheel pattern for the Farmall 50A, 60A, 70A models with the MFD front axle (9.5-24 R1 tire)? Or otherwise, front wheel spacer dimensions?
Thanks!
   / Farmall 50A, 60A, 70A Wheel Spacers #2
Good luck on finding ANY wheel spacers anywhere. Most places are on back order for 18 to 24 months.
Most of the spacers are made from 6061-T6 aluminum; durable, holds up well and resists corrosion.
2016 HAMM HD+ 120I SMOOTH DOUBLE DRUM ROLLER (A51246)
2016 HAMM HD+ 120I...
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
2004 CATERPILLAR D6R XL CRAWLER DOZER (A51406)
2004 CATERPILLAR...
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
New/Unused 7ft 35 Drawer Stainless Steel Workbench (A51573)
New/Unused 7ft 35...
2017 FORD F-550 XL SERVICE TRUCK (A51406)
2017 FORD F-550 XL...
