Technocrat
In reassembling the steering linkage on my H (I did dot do the dis-assembly) I noticed a key-way for a woodruff key in the steering shaft, on the end that slides into the u-joint. The joint assembly has a key slot, but it is only about half as wide as the one in the shaft. Is there supposed to be a key here, or is tension from the lock bolt (which does not go thru the shaft on this tractor) supposed to hold the shaft??
Thanks in advance for any help.
Techno
Techno
