Farmall M Engine Knocking
   / Farmall M Engine Knocking #1
cm9
Farmall M
Hey everyone. I have a Farmall M with a loud knocking noise coming from the number 1 cylinder. Tractor will hardly move,misses and knocks loudly and is definately down on power. If the number one cylinder wire is unplugged the tractor runs without knocking albeit down a cylinder. There is also some oil blow by coming out of the air filter. Anyone have any suggestions? Thanks....
   / Farmall M Engine Knocking #2
It sound like you have a sparkplug wire hooked up wrong which is causing big ignition advance in that cylinder. If it was a bearing or a wrist pin they wouldn't stop knocking when the plug was disconnected. It might be two of the 4 cylinder plugs are on the cylinder but only one is firing early enough to effect the engines sound and performance. Any other info on how this occurred. After changing plugs, working on distributor, ect.
My dad had the distributor cap off but that is it.
   / Farmall M Engine Knocking #4
When it was off were the plug wires removed. If so there is a slight chance that one plug was put on the wrong plug at the distributor. I don't know the firing order but you might be able to take one plug out at a time and check to see if it is firing around top dead center on each cylinder. If two are out of time try switching them around and see if it makes a difference. Before you go pulling plug wires, label the order of which one goes were.
No the wires were not removed.
   / Farmall M Engine Knocking #6
Go back to the basics and check the timing of the distributor ,check the cap has number one lead inline with the rotor when at TDC on cylinder number 1.Check plug gaps .It will something simple like that,as these are a basic system.Firng order will be 1-3-4-2 but I am not sure of the rotation.
Thanks I will give it a shot tomorrow.
Checked it out today. Started up no problem but was still knocking. We unplugged the number one wire and it went away. Plugged it back in and the knocking noise was still gone. It did come back after a few minutes. Going to change plugs, wires, cap,rotor, condenser and points tomorrow.......
   / Farmall M Engine Knocking #9
I'd suggest copper core wires.
   / Farmall M Engine Knocking #10
Seen this before, yes number one has something wrong! To miss match plug wires or disconnect them will get rid of the noise because there is no load.
2014 FREIGHTLINER M2 REAR LOADER GARBAGE TRUCK (A51219)
2014 FREIGHTLINER...
2020 SOUTHERN WELDING PNEUMATIC SAND TRAILER (A50854)
2020 SOUTHERN...
72in Rock Bucket Skid Steer Attachment (A50322)
72in Rock Bucket...
2013 VERMEER RTX1250 RIDE ON TRACTOR (A51242)
2013 VERMEER...
2018 Toro Sand Pro Bunker Rake with Edger Broom (A49461)
2018 Toro Sand Pro...
HOPKINS 40 TRI-AXLE DATA VAN TRAILER (A50854)
HOPKINS 40...
