Hello all!
I am a newbie! I've got a '63 JD 3010 that has a Farmhand F11C Loader on it with a 540 PTO pump and a stock Farmhand 5 gal oil resevoir.
Problem is my pump went bad. Internal casing worn out & bypass goin on. I want to buy another one (rebuild is just as costly in this case).
HOW MANY GPM SHOULD I GET??? I have seen anywhere from 7 to 40 gallons per minute with those Prince pumps and am worried if I buy a high GPM pump it may blow out my old loader seals. CAN THIS HAPPEN??? Also the pump makers site says you should have a resevoir equal to the GPM! I don't have room for a 18/21/40 gallon resevoir!! IS THIS TRUE???
I have the original loader manual and parts book with all the details and drawings but nowhere does it give any specs on the pump like gpm or pressure generated???
I like the PTO pump set up and don't want to change my valves to run it off the tractor directly. Any info you guys have would be greatly appreciated!
Thanks very much!
John in AZ (oscedo)
Thanks very much!
John in AZ (oscedo)
