Farmtrac 300dtc
   / Farmtrac 300dtc #1
Pilotdcw
Stanfield nc
Farmtrac 300dtc
Anybody have any ideas why my farmtrac 300dtc is having problems with the shuttle drive? It will go into foward pretty easy but cant hardly get it to into reverse. Would low hydralic fluid cause this?
   / Farmtrac 300dtc #2
I had this problem. Turned out to be a damaged synchromesh ring in the transmission. If that's it, you have to split the tractor. It was lots of work. I used jacks under the two halves and also ropes from the ceiling to keep the halves aligned for easier re-joining. Parts are cheap, at least.
PLEASE VIEW ALL PICTURES!! (A50774)
PLEASE VIEW ALL...
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
2007 FORD F-450 (A50854)
2007 FORD F-450...
2023 John Deere 6110M Utility Tractor (A50657)
2023 John Deere...
Case 1150G Crawler Tractor Dozer (A50322)
Case 1150G Crawler...
2008 CAT 287C (A50854)
