Farmtrac 360 DTC PTO momentarily engages when clutch is let out (switch OFFposition)
   / Farmtrac 360 DTC PTO momentarily engages when clutch is let out (switch OFFposition) #1
Clevelandtx
Farmtrac 360DTC
I have a Farmtrac 360DTC, 39HP with 400 hours. I don稚 understand how this can happen so I sure could use some advice. It has an electric three position PTO engagement switch (OFF, Independent and Manual) that works properly in all 3 positions. The issue is that with the PTO Switch in the OFF position and I let the clutch out, the PTO mysteriously engages for a moment. Enough to spin up whatever is hooked up and then goes back off and functions properly until the next time the clutch is let out. Some background. This all started happening after I had the synchronizer, forward and reverse gears replaced. The repair shop said they had no idea. I am sure it is related to the repair but just don稚 understand what the problem could be. Any advice or knowledge of how this could possibly happen is greatly appreciated.
   / Farmtrac 360 DTC PTO momentarily engages when clutch is let out (switch OFFposition) #2
Did you ever get this problem figured out? I am having some what of a similar problem. Recently had the synchronizer replaced in my Farmtrac 360DTC and now the PTO wont engage. With the clutch pushed in I turn the PTO switch on, the PTO light comes on on the dash, let the clutch out and nothing happens.
More info coming soon! (A44572)
More info coming...
Open Sweeper Broom (A47809)
Open Sweeper Broom...
TPM 16 Mini Excavator (A47809)
TPM 16 Mini...
Cub Cadet 7193 2WD Tractor (A47809)
Cub Cadet 7193 2WD...
2 Bottom Plow (A47809)
40ft Shipping Container (A47809)
40ft Shipping...
