Farmtrac 535 how to check hyd. fluid?
   / Farmtrac 535 how to check hyd. fluid? #1
grandpawj
Lancing, TN
Farmtrac 535 W/ 5245 front end loader(turf tires), MFG 2006
I know it should be intuitively obvious but I am not quite sure how to check the hydrolic (I know I can't spell it) fluid. I lost some when working on my loader and need to see how much to put back in.
   / Farmtrac 535 how to check hyd. fluid? #2
On my 675 there is a dipstick behind the seat just up and right of the pto output shaft.
   / Farmtrac 535 how to check hyd. fluid? #3
On my 555 there is a plug by my right foot while sitting on it. You add fluid where the previous poster said his dip stick is. Add fluid until it comes out the hole.
I will check tomorrow. It's 10 p.m. right now. However, I do remember that my return for the Hyd fluid is right behind the seat where one would expect the dipstick to be. I am sure I will have to remove it to add fluid. Most likely I will see the plug you are referring to in the morning. Thanks for both your replies.
Yep Clint, that's where mine is too. Thanks.
   / Farmtrac 535 how to check hyd. fluid? #6
To make life easier I will just use a little hand pump and pump fluid into that hole, especially if the back hoe is on
2024 Apex Hyperdisc T26 High Speed Tiller (A46878)
2024 Apex...
2016 Ford F-250 Pickup Truck (A44572)
2016 Ford F-250...
2013 Ford F-750 VersaLift VO225 55ft Insulated Forestry Bucket Truck (A44571)
2013 Ford F-750...
2025 Wolverine TCR-12-48H Trencher Attachment (A47484)
2025 Wolverine...
2009 TRAIL KING PNEUMATIC TRAILER (A45333)
2009 TRAIL KING...
2023 Ford Ranger Pickup Truck (A44572)
2023 Ford Ranger...
