FEL 302 Float
   / FEL 302 Float #1
bigdad
Platinum Member
West Central Illinois
Kubota B7510
I need a little help with my FEL. Seems that the float feature isn't working anymore. I used to be able to push the joystick all the way forward to float the bucket. Is there an adjustment?
Thanks... Big Dad
   / FEL 302 Float
Thanks Eric...
I remember reading your thread.... now. I'll giver her a try this long weekend. I kind of miss the float option.
   / FEL 302 Float #4
I always had a battle getting my 302 into float, lube that valve linkage every time you run the loader. I had to run my machine without float working a storm with the front snowblower, it was a huge PITA!
   / FEL 302 Float
That did it! Once again the forum answers another question.........solves another problem.
2021 McFarlane IC-5140 Vertical Tillage Tool (A50657)
2021 McFarlane...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A51039)
2021 John Deere...
2007 Pace American JT716TA2 20ft T/A Enclosed Trailer (A49461)
2007 Pace American...
2021 Doyle 8 Ton Trailer Tender (A51039)
2021 Doyle 8 Ton...
FRUITLAND VACUUM PUMP (A50854)
FRUITLAND VACUUM...
2008 FREIGHTLINER FLD120 SD DAYCAB (A50854)
2008 FREIGHTLINER...
