FEL Bottom Bucket Pins
   / FEL Bottom Bucket Pins #1
htiek126
Southern Maryland
Iseki TA270F, Yanmar YM1510D, Mitsubishi MT2201D
Should the bottom pins on the FEL bucket be loose? I just bought a Hinomoto with a quick detach FEL, and I can see where the holes have been opened up from use, but they appear to originally have been larger than the pins. I took a look at a John Deere FEL with a quick detach bucket, and those pins were also loose. Perhaps it is built loose to allow the FEL arms to flex without binding the bucket joints?
   / FEL Bottom Bucket Pins #2
"loose" is not a very helpful or descriptive term to describe what you are asking us to respond to. Could you venture a guess as to what the hole diameter is compared to the pin diameter?
I have a Deere 430 FEL, and I don't think of the lower pins as being loose. There is just enough room for a good layer of grease but the pin is not sloppy in the hole. I estimate there is not a 1/32" difference in the hole diameter and the pin diameter. (Now, to clarify, I am not talking about the fixed tapered pin on the bucket that slips into the 'receiver hole' in the loader arm).
I am not at home to measure, and the holes are elongated. I would guess that the pin diameter was probably 1/8" smaller than the bucket holes, and probably 1/32" smaller than the FEL arm holes. These are the pinned joints on the bottom of the bucket that require the insertion of a pin, and not the tapered receiver hole on the top of the bucket.
Kubota TE4052T Hay Tedder (A47307)
Kubota TE4052T Hay...
2012 Hyundai Veloster Hatchback (A46684)
2012 Hyundai...
2017 FREIGHTLINER CASCADIA SLEEPER TRUCK (A45676)
2017 FREIGHTLINER...
2012 VOLVO VNL670 SLEEPER (A45676)
2012 VOLVO VNL670...
4'x8' Quick Attach Safety Basket (A47307)
4'x8' Quick Attach...
2000 Wacker Neuson WP1550 Plate Compactor (A46683)
2000 Wacker Neuson...
