Front-End Loader FEL bracing
   / FEL bracing #1
RProv
North Franklin, CT
Bolens G194/Iseki TS1910F
I知 finishing adapting a Kubota LA402 FEL to my Bolens/Iseki G194/TS1910F. Found the loader in
the junk yard on it痴 tractor after the tractor had been in a fire. Unfortunately someone had gotten the
bucket before me but I found a B1616 bucket on-line. I adapted the Belly bar to bolt on to the
mounting bosses on either side of the bell housing. I adapted the front brace that goes from the towers
to the front frame. Plumbed up the hydraulics and it works. I have only to run the two rear bars that go
from the belly bar back to the rear axle assembly.
My question:
What do you guys think of triangulating the two rear bars back to the 1 pin that the rear hitch attaches
to? The 5 OEM plow blade was triangulated back to this and it is a pushing machine. In snow or dirt
it will push like ****. It痴 attached with two pins to the front and two box tubing bars go back to the 1
pin on bottom of rear end. I figure if it痴 good enough for the plow than it痴 ok for the FEL. What say
you?
Thanks,
Rich
2006 DITCH WITCH RT40 RIDE ON TRENCHER (A51242)
2006 DITCH WITCH...
2017 Ram 5500 4x4 Utility Truck, VIN # 3C7WRNEL7HG551780 (A48836)
2017 Ram 5500 4x4...
RURAL KING RK37 TRACTOR (A51243)
RURAL KING RK37...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A52128)
2020 New Holland...
Zero Turn Mower (A48082)
Zero Turn Mower...
2002 KENL 12 Ft Enclosed Trailer (A50324)
2002 KENL 12 Ft...
