FEL Bucket with a smileyface?
   / FEL Bucket with a smileyface? #1
jokerman
Hi,
I've got a Kubota B7510 that I've used for some heavy duty landclearing and managed to bend the bucket so the bottom edge / surface isn't flat anymore.
Does anyboy know of some way of straightening/flattening it back again??
Thanks /forums/images/graemlins/laugh.gif
   / FEL Bucket with a smileyface? #2
I put a slight bow in the bucket of my L3000DT trying to move some large stones. I found a tree I didn't care if the bark got messed up a bit and put the bucket at the right angle then pushed on the tree until the bow went away.
I am sure that it wil not take as much force to bend it back into a smile again next time. I am sure others have had to wipe the /forums/images/graemlins/smile.gif off the face of the bucket before too, so I bet there will be many other suggestions.
Randy
   / FEL Bucket with a smileyface? #3
There was a discussion here a few months back on this. Couldn't find it right now. My way has been to chain the bucket on each end to something solid, in my case a trailer frame made of 8" channel iron, , then use a bottle jack in the middle. I've also been known to find a sturdy stump and abuse my bucket in the opposite direction.
   / FEL Bucket with a smileyface? #4
Here is one thread on the subject. Click Here
I straightened a cutting edge with a fine thread clamp and short chain.
Thanks for these past few additions to the thread. I think I got a few ideas to works with!!
Thanks for taking the time to help out!!!! /forums/images/graemlins/wink.gif
   / FEL Bucket with a smileyface? #6
I had to cut the bottem off my back hoe bucket and replace. You can buy the cutting edge. Use 1/4" for bucket. Get 3" x 1/4" strap for the wear plates on the bottem.
John
   / FEL Bucket with a smileyface? #7
I used a farm jack to pull mine back straight - hooked on the top edge of the bucket then pulled it in
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A53843)
HYDRAULIC THUMB...
2014 Jacobsen AR3 Commercial Mower (A53421)
2014 Jacobsen AR3...
JOHN DEERE 7210R TRACTOR (A51247)
JOHN DEERE 7210R...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
American G-Model Pump Jack (A55218)
American G-Model...
