FEL bushing removal help?
/ FEL bushing removal help? #1
SouthernThunder
I am having a lot of trouble getting the bushings out of my front end loader on my backhoe. It is a Massey Ferguson industrial model 34. I tried a slide hammer and a 3 jaw bearing puller... broke them both. I also used a hack saw to cut it into 3 pieces and tried to chisle them out but it won't budge. The bearing is 1 3/8" by about 2" long. I'm kinda hesitant to apply a torch... Anyone have a solution?
/ FEL bushing removal help? #3
I have seen welded up bushings in JD industrial backhoes. The weld is ground away and a new bush welded back in when needed.
Are you sure it is a removable bushing? Maybe you need a bigger hammer.
All the best,
Martin
207273 (A52708)
207273 (A52708)
2001 International 4000 DT 466E (A60462)
2001 International...
DEUTZ MARATHON...
UNUSED FUTURE ML32 - 32" MINI HYD MULCHER (A52706)
UNUSED FUTURE ML32...
2017 Wacker Neuson LTV6 Towable Light Tower (A56857)
2017 Wacker Neuson...
2009 Kubota RTV1140 (A57149)
2009 Kubota...
