FEL Float Position
   / FEL Float Position #1
TNhobbyfarmer
Veteran Member
Middle Tennessee
Kubota L3430 Polaris Ranger 500
I have owned 2 previous tractors but my present one is the only one that has had a FEL. I have used it quite a bit in the last 8 months but am still not quite sure the purpose and proper usage of the float position. I really haven't utilized the float position. I'm sure it has a reason for being there and would appreciate input on when and how I should use it.
   / FEL Float Position #2
I set the bucket level and then lower the bucket such that it is touching the surface (ie your not digging in to the roadway) moving the control lever momentiarly all the way forward. Now the bucket will 'float' above the surface. This is useful for grading and clean up of debis, rock, roots, brush etc.
I hope this helps. Jim
   / FEL Float Position #3
Float is really great for pulling snow away from garage doors, vehicles and such. I have used the float going forward (for snow removal) with the bucket on the ground, slightly curled. That works for moving snow to a degree (without digging into the gravel drive), but isn't particularly effective...the bucket tends to ride up over the snow.
I also use float for back dragging dirt to smooth it out or distribute it from piles.
   / FEL Float Position #4
The Float position connects the 2 working ports together on the FEL lift circuit. This allows the FEL to set on the ground under it's own weight and folow the contours as the tractor moves. Without Float, the FEL bucket is hydraulically coupled to the tractor frame. If the front tires go into a hole(or the rear tires over a rise), the FEL bucket digs in, If the front wheels go over a high spot(or rear into a hole), the fel bucket leaves the ground. I usually use it for finish smoothing the soil after doing some ground work.. IE: dig/pull out a stump, fill in the hole and using the float position, smooth out the finished product to match the surrounding terrain. You can control how agressivley the bucket edge digs into the soil by setting the dump/rollback angle. It usually works better backing up because you have better control of the bucket angle and the assembly won't dig in and attempt to raise the front of the tractor such as it will when going forward(imagine a pole vaulter). When backing you can set the bucket from parallel with the ground to perpendicular(or beyond) like a rear blade or anywhere in between. My current tractor loader valve dosn't have float. Got a very good deal on the setup but this is my only complaint. I plan on changing out the valve to one with float in the spring as it is much less work to get good results.
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2014 PETERBILT 367 (A52472)
2014 PETERBILT 367...
2016 Ford Explorer...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
