FEL Leakdown
   / FEL Leakdown #1
mkyaky
Millmont Pa
Bobcat ct230
Have a Bobcat 230 with the 7 something loader. Is it normal that if I raise the loader to the top with the bucket empty for the arms to lower about a foot in ten minutes of operation? Seems annoying but is this normal. Only have 100 hrs on tractor. Dont want to bug dealer if its ok. Thanks Mike
   / FEL Leakdown #2
If they designed a 99% good hyd system, a cyl would lock with valves in neutral, and stay up for days weeks, or even months.
If a cyl or cylinders set leak down, it is probably the seals, and maybe the valve.
Both can be checked for leakage. I am sure the dealer has a leak down rate that is a go or no go situation.
The leak down for you might be different, and is what you can accept.
If he claims different, check out some of his other equipment.
   / FEL Leakdown #3
If it's still under warranty I would be calling the dealer.
   / FEL Leakdown
Yes I guess I should at least give him a call. Its just inconvenient to have it transported if it is normal.
2017 Ford F-350 4x4 Crew Cab Flatbed Service Truck (A52377)
2017 Ford F-350...
434669 (A48836)
434669 (A48836)
2025 New/Unused LandHonor Leaf Blower (A51573)
2025 New/Unused...
Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A51691)
Godwin CD150M 6in...
27ft x 24ft Metal Building (A51573)
27ft x 24ft Metal...
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A52748)
2007 Freightliner...
