FEL linkage grease and brushhog gear box oil
   / FEL linkage grease and brushhog gear box oil #1
DanielTerence
Bronze Member
Kubota L2800
Lubed all the zerks on my L2800 FEL (was a challenge getting the grease gun adaptor off/on each one) and then noticed that I'm supposed to also grease the linkage. Exactly where is this? Are there zerks involved or am I just spreading grease?
I was also told to check the Internation brush hog gear box and add gear oil once in awhile. I've got two square shaped bolts on the gear box (on on top, one on the side). What do I do?
Thanks in advance from a real novice. but lovin' every minute.
   / FEL linkage grease and brushhog gear box oil #2
On a KingKutter mower, the upper plug is for adding the oil and the lower and smaller is the "fill" line. When it runs out of the smaller plug, youv'e added enough. That way you don't overfill. Not sure if the set up is exactly the same on your unit.
   / FEL linkage grease and brushhog gear box oil #3
I just did the same for the first time on my B3030's loader. I found two zerks for the HST linkage by looking at the linkage apparatus right underneath the right floorboard (right below the HST pedal). I looked for more, but's all I could find. A little graphic in the manual would have helped.
   / FEL linkage grease and brushhog gear box oil #4
My landpride rotary cutter{bush hog} is the same as mentioned above add oil in the larger hole,just when it starts to run out small hole stop.
Swict 78" Bucket (A50121)
Swict 78" Bucket...
2021 MDB TF150R 84" HYD MULCHING HEAD (A51406)
2021 MDB TF150R...
2013 Nissan Pathfinder SV SUV (A50324)
2013 Nissan...
43018 (A51691)
43018 (A51691)
2017 Buick Encore SUV (A50324)
2017 Buick Encore...
2025 Kivel 24in Forks and Frame Mini Skid Steer Attachment (A50322)
2025 Kivel 24in...
