FEL
   / FEL #1
mf1145
My FEL model # 1246 has a small problem if you get a full load in the bucket and raise it up and try to lower it with out dumping it, it wants to fall real fast , is ther an adjusment on the control valves , i did check for bypass from the cyclniders by getting a full bucket of dirt and rasing it and measuring and it lowered 3 inches in twenty minutes good or bad?
   / FEL #2
mf1145,
You have to feather the control valve. Its like turning on the water at the kitchen sink, if you just open it a little it goes slow, if you open it more it goes faster. The more weight that you have in the bucket the more pronounced your movement is. As far as dropping 3" in 20 minutes, that is normal for very very many loaders. Most of the time there is nothing really wrong. What it is, is the stack of tolerances in the control valve. The spool has to some clearance or you wouldn't be able to push it in or pull it out. If the tolerances are on the high side for the valve body and on the low side for the spool, you will get a loader that drops faster.
   / FEL #3
mf1145,
My tractor also has a 1246 loader and I have found that if the joystick linkage is too tight it can cause this. Slide the boot back on the loader control valve and see if the linkage moves freely (engine off and loader bucket on the ground of course). I use a light silicone spray lube on mine, also check that the nuts that attach the ball joints to the joystick are not too tight so as to cause the ball joint linkage to bind, the joint itself should be free and loose and the linkage must move freely throughout its travel. The 1246 controls are a little sensitive anyways, and if there is any binding in the joystick linkage its impossible to have smooth control. Mine works fine and with a little practice its possible to lower a loaded bucket with precision. Another thing I like to do is spray a little Armorall on the rubber boot to keep it flexable, don't get any on the linkage though.
   / FEL
Thank you Both very much for the information it is very much appriceated...
2014 INTERNATIONAL MA025 26FT NON CDL BOX TRUCK (A51222)
2014 INTERNATIONAL...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
2022 Mack MD Rollback Truck (A50323)
2022 Mack MD...
91013 (A48082)
91013 (A48082)
1981 CASE 580D BACKHOE (A51242)
1981 CASE 580D...
