Ferguson Hydraulics
   / Ferguson Hydraulics #1
mikefinger
Saugerties, NY
Ferguson
I am taking possession of a 1952 Ferguson TO 30. Is there a way to add hydraulics to this tractor? It has a working 3 point hitch and is in pretty good condition over all.
   / Ferguson Hydraulics #2
it HAS hyds.
the 3pt isn't lifted by magic!!!
you can tap the 3pt hyds by chaining them down and diverting oil to a valve to run.. say.. a lift implement wheel cyl.. or to a OC valve for a loader.
you can also add a stinger pump and then have your choice of flow rates and capacity pumps..
Thanks, I knew the 3pt was hydraulic because Ferguson didn't develop the magic 3pt hitch until much later. Lol. I could have worded that better. I was wanting to add remotes to run other implements. Is a stinger a pump that runs off the pto? If so that sounds like it would give better flexibility of possible implements.
   / Ferguson Hydraulics #4
stinger pumps run off the crank snout.. pto pumps are available. BUT.. with a non live pto. it can be a hassle.. and also sometimes it messe sup 3pt geometry fro implements that use the pto.. even with a passthru long pto stub.
pto pump is usually cheaper and easier to setup than a stinger pump.. so no free lunch either way.
if you just needed low flow and temp use.. again.. like a lift wheel on a pull implemnent.. you can chainthe lift and use diverted flow witht he 3pt control for a sa lift cyl.. or if needing DA cyls.. get a cheap OC da log splitter valve ( less than 100$ ), and can get by that way with about 2.85gpm / 1500-1700 psi 3pt pump hyds.. )
   / Ferguson Hydraulics #6
let us know how you make out.
Will do, it might be a couple months though. Have to get a few other projects ahead of it.
   / Ferguson Hydraulics #8
cool. good luck and post back when you get to it.
   / Ferguson Hydraulics #9
I sure the hydraulics on your TO 30 are better than the hydraulics the TO 20 I once had. I had every old tractor mechanic that I could find try to make my hydraulics better. It didn't work out. Got rid of the TO 20 for better hydraulics. The hydraulics on the tractor I have might not be the best, but they are waaaaaaaaaaaaaay ahead of the TO 20 I once had
   / Ferguson Hydraulics #10
at best.. the early hyds were 1500-1700 psi and 2.85 gpm.. IF the relief was working, and the piston to cyl seal was good, and the chambers were good...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A51406)
2006 INTERNATIONAL...
2014 Freightliner M2 106 Ambulance (A51692)
2014 Freightliner...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
2008 Toyota Tundra Crew Cab Pickup Truck (A51692)
2008 Toyota Tundra...
CFG Industrial SAII100 (A50123)
CFG Industrial...
2009 Volvo VHD Tandem Dump Truck, VIN # 4V5KC9EF19N270338 (A51572)
2009 Volvo VHD...
