Ferguson model 22 disk.
   / Ferguson model 22 disk. #1
ozark48
eastern IA
d14 allis d17 allis massy 1736
Have a question, on the ones with the wood bearings did you take them apart and pack them or were there grease zirks? I looked at one today and it had 2 zirks on each bearing housing. Looks in good shape,one outer disc blade missing and a lot of nuts bolts are not rusted up so looks like its been gone over recently. Was going to offer him $300 but not sure if I want to deal with wood bearings if that's the case. Thanks
   / Ferguson model 22 disk. #2
Mine has Zerks. I bought the disk 20 years ago, and the wood bearings are just fine. I was thinking of changing mine, but after taking the caps off, they were in great shape. There is/was a company that still made new wood bearings for them. I believe found them by doing a google search, using the bearing part number.
The hand lever adjust is great for setting at full cut to work down plowed ground, then set to partial cut for a finish. I can't even imagine using one where you have to unbolt the gangs to adjust the cut.
I gave $270.00 for mine 25+ years ago, and that was considered a steal. They still command a good price at dealers.
Thanks DJ54. Found a company called woodex bearing company that makes them. Going to see if he will take $300. Its about 6 miles from home so I can drive tractor over hookup an go if it works out.
   / Ferguson model 22 disk. #4
Wow..!! Lucky you..!!
2019 UTILITY 53X102 REEFER TRAILER (A52576)
2019 UTILITY...
2014 Nissan Pathfinder SUV (A51694)
2014 Nissan...
John Deere MX 8 Brush Hog, 8', 3pt Hook Up, PTO  (A52384)
John Deere MX 8...
2001 CATERPILLAR 140H VHP MOTORGRADER (A51406)
2001 CATERPILLAR...
2018 JLG 3246ES 32ft Electric Scissor Lift (A51691)
2018 JLG 3246ES...
