Ferguson TO-35 Pops out of Hi-Lo
   / Ferguson TO-35 Pops out of Hi-Lo #1
veedub
Moretown, VT
None yet.
I have a '55 To-35 I have had it for about 5 years and received it from the previous owner with a loop of wire that holds the shifter forward in Lo gear, If you don't slip this loop over the shifter it will pop from gear after a short while, which is really fun if your headed down a steep hill using the engine as braking. It occasionally will pop from high gear as well but this is more rare, but I also rarely use hi gear for the work I am doing. I have to split the tractor soon to fix a leaking seal and figured I should look into this issue while its apart. Any guesses as to what my issue is?
2013 VOLVO VNM TANDEM AXLE DAY CAB (A52141)
2013 VOLVO VNM...
2020 KENWORTH T680 SLEEPER TRUCK (A52141)
2020 KENWORTH T680...
SpotWeld RockerRite 480V Arm Type Spot Welder (A50322)
SpotWeld...
Bobcat T650 Skidloader (BURNT) (A50774)
Bobcat T650...
1263 (A50490)
1263 (A50490)
2014 BMW 328I (A50120)
