weavertg14543
- Joined
- Aug 17, 2017
- Messages
- 47
- Location
- rush,ny
- Tractor
- john Deere gator 6x4 ferris pro cut s 61 inch 67 cub cadet Kubota ls3130
So newest issue with the mower is it seems that it will occasional bog down. Not when in tall grass just like driving down the driveway headed to the lawn. The speed will go in half and it can barley spin the blades. If I give it a few minutes or will all of a sudden pick up again. Makes me think it's a has problem. Like maybe the machine is not getting enough gas or too much gas or something. If any one has any ideas that would be super helpful.
Next issue is it is scalping. Ideas on how to fix that cause that just sucks.
As far as the battery not staying charged idk it's getting 14.5 volts when running. Not sure where the power goes. It's a 350 cca and 300 ca normal it is new this spring but the sticker says from 2016.
I think I might just hard wire a trickle charger to it for now.
Has any one mounted led lights. I work days now and don't have enough time to mow cause the sun is going down so early. So kinda want to mount some lights. Has any one tried that. How did it go. What problems have you run into. I saw some led lights that were battery powered with magnets and were rechargable at Napa liked the no holes having to be drilled idea.
