FERRIS IS700Z FUEL TANK MOD
   / FERRIS IS700Z FUEL TANK MOD #1
Jimmy Joe
Medford Wisconsin
I always hated filling the gas tank on our Ferris mower as in order to get it to the full mark you had to fill slowly once it got up to the bottom of the filler neck which extended down into the tank a bit. Always spilled fuel as it reached the bottom of the filler neck and no way for air to escape.
My solution was to remove the fuel cap and stuff a rag in the filler neck about 2 inches from the top then drill a 1/4 inch hole in the inside of the filler neck about an inch from the top. There is a void behind the filler neck where more fuel can go if the air can escape. The tank is plastic so the rag catches the plastic shavings and you just pull it up with the shavings or you could suck them up with a shop vac.
Now when I fill the tank the air is allowed to escape and the fuel tank reads full and way less spilling, I am sure there are other mowers with similar tank designs.:thumbsup:
   / FERRIS IS700Z FUEL TANK MOD #2
Good idea. Wondering if they extended the neck down farther for more support for funnels and such ??
Allis Chalmers D17 Tractor (A46502)
Allis Chalmers D17...
2025 Kearney 76"X16' Trailer (A47307)
2025 Kearney...
CAT 259D Skid Steer (A43476)
CAT 259D Skid...
2016 Chrysler 200 Sedan (A46684)
2016 Chrysler 200...
2018 Chevrolet Equinox 1LT AWD SUV (A46684)
2018 Chevrolet...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A46683)
2025 Kivel 48in...
