furnacebrook
I have a question about filling the back tires on my Case580CK. Checked with my dealer and looks as if I need about 47 gallons each to fill them to 75%. Problem is the Rimguard stuff they use is $2.75 a gallon and that does not include getting it there. It's getting expensive as you can see. Now I have read that some use washer fluid and others are using anti freeze........I'd rather not go the cloride way event though it probably is the cheapest. I have the tire adapter and would rather do it myself.The weather here can go well bellow zero in the winter so whatever I use has to be 20 below at least. The washer fluid is that number to start and is going for $1.99 a gallon here at my TSC store. While I was there I noticed they have RV anti freeze going fo $3.15 a gallon and its good for 50 bellow. I don't need it that far down but if I mix it 50/50 with water will this stuff not dilute past minus 25 or so? It says not to on the bottle but thats for the intended use not for tires. It is glycol based and I'm not sure if it behaves like regular anti freeze. I'd save about 40 bucks if I went this way instead of the washer fluid.
Thanks for any input,
Scott
Scott
