Filters...Again!
   / Filters...Again! #1
barticus73
Clarksburg, Pa(Between Indiana and Saltsburg Pa)
Cub Cadet 7272,Farmall 544
Well, its time to do the maintinance stuff on my CC 7272 again. I did the cross reference dance on the Wix site and called around and came up with some interesting results.
......................CC Part#............Wix Cross #.....Napa Gold Cross #
Fuel Filter.....MA-MM404879..........33264...............FIL 3264
Oil Filter.......MA-30A40-00100......51356................FIL 1356
Hyd Filter.....MA-19642509000......57118................FIL 7118
Air Filter......MA-10310511200.......46387................FIL 6387
Now for the prices:
................Cub Dealer..............Napa Gold
Fuel.............13.70.....................8.49
Oil...............20.27.....................7.09
Hyd.............42.21.....................74.79
Air...............87.96.....................32.79
It seems to me the hyd filter at the cub dealer has actually come down in price. Hard to believe it is almost half the cost of the Napa filter! What a switch. The other filters though are a deal at Napa so looks like I will buy Hyd filter at Cub Dealer and the rest at the local Napa store.
As a side note, what hydraulic-transmission fluid are you guys using in these 7000 series cubs now that the warrenties are over? Mine has a loader and a hoe(the hoe I am actually picking up today!!)
   / Filters...Again! #2
I'm just finishing up servicing my 7275 and I used Mystik JT-5 in mine. It was $49 and change for a 5 gal pail at TSC.
I appreciate your post on the cross ref numbers. I got mine from a Cub dealer and felt some pain.$$$
I did find the engine oil filters here cheap enough, but when you factor in freight, it probably kills it.
Liftruck Parts, Forklift Parts, Pallet Jacks, Starters, Alternators, Filters, Helmar Inc.
Only luck I had on either hydraulic filter was here. Not that good either!
Filter-Mart Corporation - Filter information
Thanks aagain for the info,
Chuck
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A52128)
2019 New Holland...
2017 Nissan Titan SV Crew Cab Pickup Truck (A50323)
2017 Nissan Titan...
2017 Dodge Grand Caravan SE Van (A50324)
2017 Dodge Grand...
2009 Lee-Boy 8510HD Conveyer Feed paver (A52128)
2009 Lee-Boy...
20ft Anderson Trailer 14K (A52128)
20ft Anderson...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2019 Ford F-150...
