Filud in the bell housing masssey 1540
   / Filud in the bell housing masssey 1540 #1
case310350
Bronze Member
Massey 1540 Power shuttle 07. I have found the bell housing is filled with hydraulic fluid from the transmission. There is only 1 shaft coming through the transmission case to the bell housing. I do not think the seal is the cause. But suspect a crack in the trans case. Don't know how that could happen as there should be no pressure in that area. going to take off the starter and slip a camera in before I split it.
Any input or suggestions?
   / Filud in the bell housing masssey 1540 #2
You can do this job without taking the dash off. Remove the injector lines and intake tube. This is so you can remove the fuel tank. You probably have a leaking rear main seal or a leaking transmission input shaft.
2014 Ford Explorer Sport AWD SUV (A51694)
2014 Ford Explorer...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
2025 JOHN DEERE X350 LOT NUMBER 166 (A53084)
2025 JOHN DEERE...
2016 Ford F-550 4x4 Bucket Truck, VIN # 1FDUF5HT8GEB70191 (A51572)
2016 Ford F-550...
2013 Ford Edge SEL SUV (A51694)
2013 Ford Edge SEL...
2015 Ford F-550 Auto Crane 4004EH 4,000LB 2 Ton Crane Service Truck (A51692)
2015 Ford F-550...
