Finally done (for now) with 2 medium range rifle systems...
   / Finally done (for now) with 2 medium range rifle systems... #1
westcliffe01
Veteran Member
SE MI
Kubota M4500DT, B200 backhoe
Since getting my green card and being allowed to be a firearm owner again, I had a rather protracted and expensive lesson in long range shooting (and I should qualify that it really is medium range in the big scheme of things since we are talking of less than 500 yards typically). Most of my experience has been in killing coyotes that caused a lot of damage on a local sheep farm.
I learned a few basic things:
1) Forget about 55gr 223 bullets if you need to shoot 250-350 yards and the wind is blowing. The wind will blow them more than 2ft off course at 350 yards with ease.
2) Once you figure out that you need to shoot high ballistic coefficient bullets (high BC) you quickly find that most factory rifles can't stabilize them. So the twist rate in my Savage 24 222Rem was limiting the bullet weight/design. Then I got a Rem 700 SPS with a 1:12 twist and while it was much more accurate than the Savage 24, it could not shoot a bullet heavier than 55gr.
3) I got the Savage 10PC with a 1:9.25 twist and it was super accurate (1/2MOA) and could stabilize 75gr HPBT bullets but discovered that the 75gr bullets were hardly "flat shooting" and after some misses at ranges either side of my 250 yards zero distance, I ended up getting a custom turret made for the scope that is calibrated for that load and the average atmospheric conditions at the sheep farm. I also had caught on by then that re-barreling a Savage was a considerably less costly business than pretty much any other gun make out there.
4) While the 223 shooting the 75gr match bullets was a considerable improvement over where I started, it was still marginal at extended range and one had to be very accurate with ranging moving critters due to the trajectory of the bullet.
So this was the point that I got a Savage 12 in 243Win. It was the stainless barrel/action with a laminate stock. it was a heavy gun, but shot really nice and starting out it shot Hornady Superformance ammo well with 95gr SST's. This was a significant step up in BC and velocity and energy and after getting to know it and putting a really nice Vortex Viper 4-16x50 FFP scope on it, the number of misses at the coyotes went way down.
With that combo I got 2 of 2 coyotes that showed up during a snowstorm in Feb his year.
Here is a layout of the land where that took place
It is not obvious from the picture, but the entire swamp area along with its draw is about 80ft lower than the surrounding land. From the swamp the lend slopes upward towads the west and east so there is hardly anything flat on this land. The red dot is where I put in a permanent blind which overlooks the valley to the west and the higher ground to the west. From this position, it is 250 yards to the far edge of the pond and 350 yards to the farthest point on the slope to the east before one can no longer have a safe backstop given all the farm buildings. To the west it is about 130 yards to the edge of a brush patch that is in front of a mixed pine/hardwood forest. Access south is limited by a heavily brushed fence row.
I found that the coyotes could easily spot me from over 400 yards away if I tried to sneak into the area during daylight, so I had to change tactics and put in the permanent blind and sneak in more than an hour before daylight. The coyotes have in more than 2 years never come in to a caller of any description including some pretty expensive Foxpro models. So sniping has been the most effective solution.
Anyway, the 243 was substantially better than anything else I had tried up to that point but I knew it could be better, so I got a Shilen 243 Ackley Improved 1:8 twist match barrel for it. With the new barrel I was able to shoot the Berger 95 and 105gr VLD bullets and that has taken the performance of this rifle to another level. I have worked up a 105gr load, but I don't need it for the ranges I am dealing with on the farm.
One of the groups doing load development. One shot pulled slightly to the right.
Here is a picture of that rig now that I am done with it.
The only thing still on the "want" list is a tan cerakote finish to cut the shine...
That then lead to building a 308 with another Shilen match barrel with a 1:10 twist rate and some load development with 175 Sierra Match King bullets. The past 6 months has been a complete nightmare to get any components, even brass. I finally got it together in the last month and loaded a batch of ammo and then I shot this group while doing "quality control"
First test group
Last test group
Finished article (same comment regarding tan cerakote being on the "want" list)
So I have to say that this is a pretty fascinating hobby. I am hoping to close on some land in southern CO later this summer and out there my long range opportunities will be improved.
I have put up steel plates at 160 and 300 yards on the farm and even the 300 yard target is too easy now. But it does give me the means to stay in tune and remind the coyotes that someone is still active in the area. The coyotes appear to have withdrawn and so far this year they have hardly even been heard at night. 2 years ago, the farmer lost 80% of his lambs and up to 20% of his adult sheep.
   / Finally done (for now) with 2 medium range rifle systems... #2
Although I enjoy your post
Percentages are for the stupid! Is 20% 2 or 20000? Without that, the comment is without merit!
On average he has a sheep herd of about 100. There are just a few rams and the ewes will have about 1.5 lambs a year so about 150 lambs. The survivors will get pared back down to 100 at the end of the season, the balance sold off. So one is talking of about 120 lambs being killed from late March when they were born through September when I arrived on the scene. Its a 100 acre property that grows more hay than the flock can consume so that is the second product. I have seen a single attack with no animals killed but which results in 2 deaths within days from shock and infection and in one case a death during the attack from heat stroke (no bite marks).
   / Finally done (for now) with 2 medium range rifle systems... #4
You have a couple of nice rifles there. I love the Savage rifles for many reasons and the ability to swap barrels yourself is one of them. However I did pick up a Mossberg MVP predator last year and it is one sweet coyote blaster. I prefer the .223 over the .243 for yotes and foxes around here as the .243 tears the pelts up so bad. I believe doping for the wind is just one more challenge for the nut behind the butt.
I have been shooting a 6.5x55 Savage in some tactical rifle competitions over the past year and I love that round.
Enjoy whacking them yotes and sending lead down range.
   / Finally done (for now) with 2 medium range rifle systems... #5
Very nice set up should help keep the dogs at a distance. I'm sitting here and can hear the dogs outside talking to each other right now.
   / Finally done (for now) with 2 medium range rifle systems... #6
Varmint control over long distances think .338 and be done with it.:thumbsup:
I think that shooting a 338 LM in close proximity to livestock will do more damage than having the coyotes chase them around. And currently any form of hunting with a suppressor remains illegal in MI.
   / Finally done (for now) with 2 medium range rifle systems... #8
Nice guns and shooting. The coyotes are thick around here due to hobby farmers and the proliferation of goats and sheep. Was putting in a fence post one night last fall and, after moving to the next corner, I remembered I had left my hammer back at the prior corner. Counted 3 groups howling to each other when I walked back to get the hammer.
   / Finally done (for now) with 2 medium range rifle systems... #9
Given the owners huge losses, does the state have a depredation permit process? NC has such a permit process that gives the landowner/live stock owner has expanded opportunity to kill the problem critter(s).
The state finally passed a regulation last year that allowed coyotes to be shot at night. Previously that was illegal unless the coyotes were in the attacking livestock. The coyotes have all but wiped out the deer herd around our house. We should be seeing 7-9 does but we are down to two. The herd in front of us seems to be drastically reduced in size as well. The coyotes have been within feet of our back door howling several times over the last year or so. Pretty sure they left a deer leg bone right off our front porch one night...
Coyote suppression is on my to do list for next fall/winter when the leaves are off the trees.
Later,
Dan
The owners interactions with local DNR were extremely negative. DNR basically said there was no concrete proof that it was coyotes and it could equally be feral dogs. Coyotes are not treated as a nuisance species here, unless in the actual act of attacking livestock. Of course if you wait until then, you are going to have lots of damage and apparently unless you have a dead coyote with a mouthful of sheep it does not meet the evidence standard. It is nearly the same kind of relationship that cattle ranchers have with the wolf in western states. Almost all of the damage is uncompensated.
Neither the farmer nor his wife are hunters, nor do they possess appropriate equipment or skill. Given the open nature of the landscape the likelihood of them ever killing one of the attacking coyotes is virtually nil. Both have part time jobs and have to attend to all the farming activities in what time is left. Add to that the fact that rifles have to be carried unloaded and cased on anything with wheels or tracks (vehicle) or face misdemeanor firearm charges and it is a losing situation all around. Neither has a CPL either, which would at least allow them to carry a loaded handgun on a vehicle. Even those have to be cased in the current scenario.
Basically, the only sure way to manage this problem is all new welded mesh fencing around the perimeter in addition to at least a 3 wire cattle fence on the inside with a high energy driver suitable for predators. That would of course require a few weeks of work with a dozer/excavator to tear out all the brush in the fence rows, followed by the cost of the new fence itself (close to 4000 yards worth). This is what one would do in a full scale farming operation, but small inherited farms like this one lack the financial resources to make it happen.
RYOBI EASY START INVERTER GENERATOR (A51248)
RYOBI EASY START...
2023 JOHN DEERE 6R 145 LOT IDENTIFIER 245 (A53084)
2023 JOHN DEERE 6R...
2018 Chevrolet Tahoe (A51694)
2018 Chevrolet...
U56 ELECTRIC FIRE PUMP MOTOR (A51406)
U56 ELECTRIC FIRE...
ECHO GT-225 GAS WEED EATER (A51248)
ECHO GT-225 GAS...
