FINALLY!
   / FINALLY! #1
hrcarver
NC
jd 6120, 7200, 7700 - ford 2910, 3000, 7610, 7740 - IH 140(2), Super A - kubota m6040
Got my new trailer. 20+2', 6k dexter axles, led's, winch mount, spring assist ramps, 10k jack. I should be able to haul my junk all around the place now!
One problem, where should I put the tags?
   / FINALLY!
6k, 9300 lb capacity.
   / FINALLY! #5
hr,
Nice trailer.
I put my license plate vertically on the back of the fender. It might not be totally correct but I've never had a problem. I see a lot of them that way and it gets it out of harms way. If you added a license plate light in that location you'd never have a problem.
   / FINALLY! #6
mine looks very simular... not enough space in the rear tail... tail lights dont stick out far enough for a full size plate...
so i went with what ive seen time and time again.... screwed vertically to the fender
and for those concerned about the safty police.
led bolts
Amazon.com: Black LED License Plate Lights Bolts: Automotive
   / FINALLY! #7
By law, at least here in Indiana, they must be under the left tail light with it illuminated at night. If you look under your light there is probably a clear lens to let some of the running light illuminate it. You can get a rubber mount at any TSC or auto parts store that allows the plate swing out of the way if you bottom out.
Chris
   / FINALLY! #9
What brand is it? Are those tor-flex axles?
   / FINALLY!
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50322)
2016 Big Tex 14LX...
John Deere 6430 Side Arm Tractor (A51573)
John Deere 6430...
TAKEUCHI TL6R SKID STEER (A51246)
TAKEUCHI TL6R SKID...
2014 Ford F-150 Pickup Truck (A51692)
2014 Ford F-150...
