finish mower belt tension
   / finish mower belt tension #1
Mosey
Veteran Member
Conifer, Colorado
2000 New Holland TC29D with 7308 FEL, and top & tilt. 1950 John Deere B. 1940 Farmall A.
The manual for my LandPride finish mower says to check the belt tension by checking the force to move a certain point on the belt a certain distance and it should be 7-10lbs. I was planning to use a fish weighing scale, the type that you just hang the fish from. Will that be accurate enough?
Well, no one responded, but I thought I’d update this anyway. I tried using the fish scale. The manual said to check the force to move the belt a quarter inch, but it took less than 1lb on the fish scale. There is a spring going to an idler pulley and the spring was barely under tension, if at all. So, I adjusted it so the spring started to open up, which required tightening the adjusting nut about a quarter of an inch. Now the fish scale reads 3lbs. The mower is 2 years old and this is the first time I’ve adjusted it. I has about 100 hours on it.
   / finish mower belt tension #3
Sorry, Danny, I hadn't seen this message until now (can't keep up anymore), and this is purely personal opinion, but I think the fish scale method should work just fine (if your fish scales are anywhere close to accurate/w3tcompact/icons/laugh.gif).
Bird, I know what you mean. This site is really active! But, that's what makes it good. Thanks.
   / finish mower belt tension #5
Danny,
Just like Bird, I finally got around to checking on some threads that I haven't had time to look at, and that's when I found this one./w3tcompact/icons/smile.gif
Your fish scale will probably work just fine. I use a similar kind of scale to test the amount of pull it takes to open the doors in our municipal buildings to meet ADA regulations. I bought my scale, which is made by Hanson, in Shubuta, MS., in a regular hardware store. It's called the Viking, Jr.
After using this scale for a few years, I started to feel a little concerned about it's accuracy. So I brought in a consultant to check the doors for me. After using his fancy test equipment (which didn't look all that different from my little scale - but cost a whole lot more!! /w3tcompact/icons/shocked.gif), it turns out my scale was only off by about 2 lbs. Not bad, really. Now I simply adjust my readings by that 2 lbs., and I'm right on.
So I think for your intended purposes, your scale should be O.K. Like Bird said, if you can, have it calibrated against another scale just to ease your own mind. /w3tcompact/icons/smile.gif
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51219)
2015 FREIGHTLINER...
2004 KENWORTH BUCKET TRUCK (A50854)
2004 KENWORTH...
2019 VOLVO VNL HIGH ROOF SLEEPER (A50046)
2019 VOLVO VNL...
2016 Chevrolet Cruze Sedan (A50324)
2016 Chevrolet...
LINK BELT LB-98 LOG LINE YARDER WITH MOTORIZED CARRIAGE (A51222)
LINK BELT LB-98...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
