Finish Mower Rebuild
   / Finish Mower Rebuild #1
mswanson
Bronze Member
Albany, NY
NH TC33D
Hi All,
Thought I would post this to see if anyone has any advice. I just picked up a used 72' finish mower for my new NH TC33D. It was made in Canada by a company called Seaforth. I couldn't find anything on them so I am assuming they are nolonger in business. There are 2 large belts that need replacing because they are streched out such that the tensioning adjustment is maxed out. These I probably can get at NAPA. The big problem is one of the spindles has play in it making me think that it's bearings are shot. There are 3 bolts holding it onto the deck. My question is can the complete spindle be replaced by a standard one? Will this make it out of balance? Am I out of luck if the company is out of business. Any advice would be greatly appreciated!
   / Finish Mower Rebuild #2
Loose spindle:
If you think the bearing is shot you should be able to replace it as it will, hopefully, be a standard bearing available locally.
eg. As an example the front wheel bearings on a 1952 international 1/2 ton were the same as on my 66 chrysler of many years ago.
Egon
Thanks! I called them and they provided information and will be sending me a manual. Apparently they don't make this single 72'' "small" deck anymore. They now specialize in very large multi deck mowers for golf courses, etc.
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2018 Komatsu WA500-8 Articulated Wheel Loader (A50322)
2018 Komatsu...
2018 Nissan Pathfinder SUV (A50324)
2018 Nissan...
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
1999 Ford F450 Dump / Plow Truck (A50514)
1999 Ford F450...
2014 Chevrolet Tahoe SUV (A50324)
2014 Chevrolet...
