First bale always falls apart
   / First bale always falls apart #1
Jkrph
Kioti CK35SE
I have a New Holland wire baler that runs great, except that the first bale always comes apart as it leaves the machine. I believe it is because there is nothing to apply pressure/compression so the bale is not well formed.
Does anyone have a good way to help the first bale get some compression?
   / First bale always falls apart #2
As far as I'm concerned, that's just the way it is. If you clean out the entire bale chamber at the end of the season, you're going to have a loose bale or two until you pack some hay into the bale chamber for the plunger to compress hay against.
I do not clear out my bale chamber during the season unless I have a problem or accidentally get into some hay that's damp, so this is a two-minute / once-a-year exercise for me. Just carry this loose hay around and feed it back into the baler as it comes out of the chute. The first bale to hit the wagon in the spring is usually the third one that actually exited the baler.
You can always leave hay in the bale chamber if you know it's completely dry and you store your baler in-the-dry. Another option is to just bale a couple of dry bales in the barn to get things started before you head out -- I'd rather do it in the field instead of carrying a couple of bales back out with me.
   / First bale always falls apart #4
Yep, it’s a beginning of the season ritual played out all over the country.
If you think you got it bad, try cleaning up a loose 4x4x8 large square that fell apart 😲
2015 Chevrolet Tahoe SUV (A49461)
2015 Chevrolet...
2015 John Deere 8345RT Track Tractor (A50657)
2015 John Deere...
2008 CATERPILLAR 304C CR EXCAVATOR (A51242)
2008 CATERPILLAR...
2020 MACK PINNACLE (A50854)
2020 MACK PINNACLE...
Hilti TE 2000-AVR Electric Jack Hammer (A49461)
Hilti TE 2000-AVR...
2011 Nissan Titan SV 4x4 Crew Cab Pickup Truck (A50323)
2011 Nissan Titan...
