First Regen
   / First Regen #1
bwmarine
western michigan
cub cadet 7235
Ok, had to pull manual out as not knowing what to expect... got through the first one... thinking another 2 times I should have it figured out lol.
Now knowing what to expect I think things will go more smoothly in future. Once in regen it took about 10 minutes to complete. Apps 25 hrs for first regen...
   / First Regen #2
Mine hasn't done a regen yet but just curious, what was there to figure out?
   / First Regen #3
My first regen occured at 27hrs, and just like it's on a timer, it has always automatically regen every 26 to 28 hours. Just remember to keep your rpm up higher than normal, and it will do a clean burn out of the particulates in the DOC/DPF.
   / First Regen
I use my tractor for moving boats and material handling and don't use full load on engine unless using for grading or snow removal.
When engine was ready for regen I had to manually go into regen. A learning experience is all I can say...
   / First Regen #5
I sure my tractor going to do a regen soon i have about 23 hr .I check the other day the regen was only at 20%.I guess il have to read up on this .
   / First Regen #6
My L4060 soot % varied wildly based upon use over the first 100 hours or so. I could start out the day at say 50%, run it hard for a few hours and it would drop to 20%.
After 500 hours I average about 55 hours between more consistent regens. I schedule my work when a regen is due so I can work through the burn and avoid a parked regen.
   / First Regen #7
Just did my first regen the other day had about 55 hr it lasted about 10 minute .was cuttin thegrass so the tractor was running a about 2400 rpm .
2014 Dodge Ram 5500 4x4 Bucket Truck with Altec AT40M - 45FT Boom, Jib Winch and Utility Bed (A52128)
2014 Dodge Ram...
2019 PETERBILT 579 SLEEPER (A51222)
2019 PETERBILT 579...
2003 PETERBILT PB 330 WATER TRUCK (A51243)
2003 PETERBILT PB...
2008 New Holland B110 MFWD Loader Backhoe (A52128)
2008 New Holland...
2019 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A51242)
2019 CATERPILLAR...
CAT 973 (A47384)
CAT 973 (A47384)
