First time buying a tractor tips?
   / First time buying a tractor tips? #1
Rbp_280z
None Yet
Hi everyone,
My family and I bought our first property on 10 acres. We need to get our first tractor for to do a few various tasks: drilling holes for fence posts, creating a fire break, plowing, mowing the lawn, moving soil, etc. the tractor will stay at our property and will be used maybe 2-3 a week.
I’ve never shopped for a tractor before so I wanted to get some advice before going to the dealerships. We wanted to buy a brand new one so we can finance it. We are in Dixon California.
  • What brands do you recommend?
  • What size tractor would you recommend?
  • Are you able to negotiate on pricing for tractors or ask for attachments? Do dealerships have tractors ready to be taken home or are they built to order?
  • Are there any other tips you recommend on buying and owning a tractor?
   / First time buying a tractor tips? #2
My family and I bought 10 acres in California.
Is this ten acres flat and smooth, or sloped? Rough land and sloped land requires a wider, heavier tractor for stability.
Will all ten acres be worked with the tractor, or only part?
The design of the Three Point Hitch tractor has been marketed in the USA since 1939 -- 83 years in 2022.
The basic design is generic.
Kubota and Deere have most of the market through 6,000 pound bare weight tractors. But this Kubota/Deere predominance is regional.
The up and coming tractor brands are Korean: Kioti, LS and Branson. There are other Korean brands. You have to critically assess dealer stability while shopping minor brands.
Korean manufacturing labor is paid ~50% of what Deere pays its union work force. Japanese manufacturing labor is paid ~70% of what Deere pays its union work force. Labor costs strongly influence tractor prices.
We have the following brands within an hour of us.
  • Kubota
  • LS
  • TYM
  • KIOTI
  • Massey Ferguson
  • John Deere
I know that a lot depends on the dealer and their willingness to help, but should I stay away from any of these brands?
Start with the nearest dealer and work out.
Transporting a tractor for service is expensive and inconvenient, whether you trailer the tractor or the dealer trailers it.
CREDIT: 'FELIXEDO'
"It has been touched on a couple of times, but not directly as a buying factor.
Every major make has a machine that will do the job(s) you want. Check out your nearby dealers, and go with one you have confidence in.
A great machine with no support nearby is a hassle to repair and maintain.
And a good machine can't make a lousy dealer into a good dealer."
Do you have any tractor operating experience?
What about a kitchen garden? Game food plots? Moving feed?
Will you plow dirt, snow, or both?
At present factory output is limited and demand is strong. Most new tractors sell at MSRP during 2022. Tractors are available with a huge number of confusing options. We can couch you through pros and cons of options. Tractor are mostly ordered then delivered after three to six months.
You should be able to test ergonomics of various tractor models at the dealers. You will spend many hours in the tractor seat operating over rough ground. Be comfortable.
The fundamental importance of TRACTOR WEIGHT eludes many tractor shoppers. Tractor capability is more closely correlated to tractor weight than any other single specification.
The most efficient way to shop for tractors is to first identify potential tractor applications, then, through consulataton, establish bare tractor weight necessary to safely accomplish your applications. Tractor dealers, experienced tractor owners and TractorByNet.com are sources for weight recommendations.
Sufficient tractor weight is more important for most tractor applications than increased tractor horsepower. Bare tractor weight is a tractor specification easily found in sales brochures and web sites, readily comparable across tractor brands and tractor models, new and used.
Within subcompact and compact tractor categories, a significant tractor capability increase requires a bare tractor weight increase of 50%. It takes a 100% increase in bare tractor weight to elicit MY-OH-MY!
Shop your weight range within tractor brands. Budget will eliminate some choices. Collect a dealer brochure for each tractor model in your weight range. I spreadsheet tractor and implement specs, often a revealing exercise. I have a column for cost per pound.
Most tractors under 3,000 pounds bare weight operate in residential or hobby farm applications on one to ten flat acres.
Selling a used tractor is easy. Selling multiple light implements in order to buy heavier, wider implements for a new, heavier tractor requires a lot of time. Depreciation on implements is worse than depreciation on a tractor.
When considering a tractor purchase bare tractor weight first, tractor horsepower second, rear axle width third, rear wheel/tire ballast fourth.
A quality dealer, reasonably close, available for coaching, is important for tractor neophytes. Most new tractors are delivered with a glitch or two requiring correction. My Kubota dealer is six miles away. I feel my local dealer continues to add value to my equipment after eight years. Dealer proximity is less important for those experienced with tractors and qualified to perform their own maintenance.
BUY ENOUGH TRACTOR​
   / First time buying a tractor tips? #4
Welcome to TBN!
You can search TBN and read for hours on advice for buying first tractors. Look under buying pricing by brand too.
That said, Dixon CA appears fairly flat if that's where your land is located? Or is it more hilly terrain, woods vs grass acreage?
Good choices are probably a tractor 25HP range, suggest HST, all major brands are good - Kubota,(L2501) Deere (2205) Kioti (2610), LS (MT225), Massey, Yanmar, and more - each brand have different features so go sit on some and figure out what fits you. You would be better off with a separate mower depending on how much grass you have.
Also it used to be normal to buy tractors off the lot, but in the market today, supply is limited so you may need to order one - they are not built to order, they are built and the dealer does the install of the tires, loader and other bits. Yes, you can negotiate a "package deal" with all your implements too - it gives the dealer a but more flexibility.
Welcome to TBN!
I appreciate the replies so far! Our property is completely flat. 90% of the property is grassy.
   / First time buying a tractor tips? #7
Answer all seven (7) questions, please.
No need to be fancy with the format.
   / First time buying a tractor tips? #8
Figure out what needs to be done and then go shopping for the equipment that meets your needs!
And do have patience.
   / First time buying a tractor tips? #9
Only thing I would add to what’s already been said is probably wouldn’t recommend mowing with the tractor unless you’re taking about brush hogging. Tractors are very slow to mow with and aggravating if you’re trying to maintain a high quality lawn. Just get a ZT for lawn mowing.
2021 Ford Explorer Limited SUV (A44572)
2021 Ford Explorer...
ESI FAST 8DX Auto Sampler with Table (A46877)
ESI FAST 8DX Auto...
2012 Ford F-150 Pickup Truck (A44572)
2012 Ford F-150...
2018 Ford Escape AWD SUV (A44572)
2018 Ford Escape...
2004 Honda Pilot EX-L AWD SUV (A44572)
2004 Honda Pilot...
2004 Sterling Acterra 1,000 Gallon Water Truck (A45336)
2004 Sterling...
