First Welding Project: 3PH Forks / Ball Hitch v1.0
   / First Welding Project: 3PH Forks / Ball Hitch v1.0 #1
DanR67
N. Central Massachusetts
Kubota B7610
Hi all,
First off - thanks to all the great ideas I've picked up here - some amazingly creative and talented people here at TBN!
Ok - when I got my Kubota B7610 this past spring - one *task* that was to be performed involved the storage and handling of wood pellet fuel that I burn for supplemental heating. This meant I needed forks to move pallets of pellets (Dr. Seuss, anyone? /forums/images/graemlins/grin.gif ) to and fro.....
After scrounging around two local scrap metal yards for properly sized pieces - I came up with the following design:
Big Pic
Big Pic
The frame is made up basically of:
6" x 6" angle iron (bottom cross member)
3 1/2" x 3 1/2" angle iron (top cross member)
3" x 4" rectangular tube (vertical members)
1 1/2" x 4" C-Channel (top link extension)
The 3PH capacity is @ 1100 lbs on the B7610 - so all steel is 3/8" or better - the lower link pin mounts are 1/2" thick.
The top and bottom cross members were found "as is" - just had to cut the 3" x 4" rectangular tube so that the distance from the top to the bottom edges was just less than the distance between the "hooks" on the forks - in this case 16 inches.
I didn't completely finish the notches on the top rail for locking the forks in position - just made a series of cuts with the chop saw - just need to clean out the scrap with my grinder....I did complete the outermost two to give me the most stability when picking up pallets.
I used the 6" x 6" angle iron at the bottom to give the widest area to mount a ball for towing my garden / clean-up cart around the yard. As the top rail will take the most load - the shorter sides (3 1/2" vs 6") should flex less - but I reinforced the ends of the top cross member just to make sure.
Finally - here's the forks in action:
Big Pic
and results of my efforts on Saturday / Sunday afternoons: 12 tons of pellets re-stacked and about to be stored:
Big Pic
This is version 1.0 - I just received a couple hydraulic cylinders from Northern Tool - one 3"x6" - one 3" x 8". Already I'm going to have to modify this a bit for attaching the cylinder (pin diameter / width is different frin top link) in place of the top link for tilt control - but tonight I think I figured out a relatively easy solution.
Then I'll just have to test out "range of motion" - the *losing cylinder* goes to FEL grapple project I'm starting next.... /forums/images/graemlins/grin.gif
All this was made possible by this monster welder I bought from the welding shop where I purchased the forks:
Big Pic
Haven't welded in about 20 years - nice to make something really useful - even the wife complimented me!!! /forums/images/graemlins/grin.gif (Disappeared just as fast when I mentioned the soon-to-be-arriving top link hydraulic cylinder /forums/images/graemlins/shocked.gif )
Hope this helps someone with their project too!
Cheers,
Dan
PS Anyone in the Central New England area looking for some forks - I've got several more pairs of forks. It was too good a deal to leave them - send me a PM for size info (5"x 42" and 6" x 48" I think?) & make me an offer! D
   / First Welding Project: 3PH Forks / Ball Hitch v1.0 #2
Thanks for sharing your project. I always enjoy seeing and reading how others solve unique and interesting problems.
   / First Welding Project: 3PH Forks / Ball Hitch v1.0 #3
Great Job !!!!!!!
A set of forks is on my wish list too. After viewing yours I wonder how much additional work it would be to make it work on the fel as well. My TC 45 didn't come with a quick tach so it would be a matter of making mounting brackets. Bet my 250 gallon water container would fit very nice on the 3 point while the fel could stack the 12 foot high pallet racking in the shop. Like you commented, great ideas and free engineering. It don't get any better !!!!!!!!!!
2023 LMC H40024 LOT NUMBER 190 (A53084)
2023 LMC H40024...
2018 FORREST RIVER CRUISE LITE CAMPER (A52472)
2018 FORREST RIVER...
2013 FREIGHTLINER CORONADO TANDEM AXLE DAY CAB (A52576)
2013 FREIGHTLINER...
(1) HD 27ft x 24ft Full Garage Kit Metal Building Frame (A51573)
(1) HD 27ft x 24ft...
2014 Utility Trailer 4000DX 53ft. T/A Dry Van Trailer (A51692)
2014 Utility...
3 Point Hitch Boom Pole (A51573)
3 Point Hitch Boom...
