Fit Rite Hydraulic Top Link Kit- Installed Today
   / Fit Rite Hydraulic Top Link Kit- Installed Today #1
shortthrow50
Banned
2012 John Deere 3520 Deluxe Cab
Took me about 5-10 minutes to install. One hose had a note to install at the rod end. Did that but not sure if it really matters the order in which you plug in to back of tractor. Anyhow, heres a quick video of operation. HAd to use the 2 ton roller so i included some video of hooking up. Ill ad more videos as i use different implements. Really LOVE this product right off the bat:thumbsup:
[ame=http://www.youtube.com/watch?v=PNN5JDkcVsQ&feature=youtube]Fit Rite Hydraulics - Hydraulic Top Link - YouTube[/ame]
   / Fit Rite Hydraulic Top Link Kit- Installed Today #2
The placement of the hoses is to allow the restrictor fitting to control the larger volume of fluid at the closed end of the cylinder, has nothing to do with directional control. Thanks for posting the video. :cool: I hope that it continues to make your life easier. ;)
   / Fit Rite Hydraulic Top Link Kit- Installed Today #3
Still waiting on my quote Brian. I'm the guy with the John Deere 5085M.
   / Fit Rite Hydraulic Top Link Kit- Installed Today #4
Nice top-link and tractor! :thumbsup: ....but it looks like it bent the hitch on your roller. :laughing:;)
I want one of those. It's on my radar.
i was just making sure i had everything hooked up right.
   / Fit Rite Hydraulic Top Link Kit- Installed Today #6
If you are to put a box blade on and have it rased up in the air. If you are to extend the cylender half way out and then drop the box blade, does the cylender stay at the same length or does it move? I have the Fit-Rite top link too and it will move and not stay at the same length all the time. It kinda acts like it has air in it, but I can't imagine there is still air in it after a year. I don't think that it is a problem with the cylender though, because I can get it to stay perfectly rock solid if I do certain things with a flow restrictor.
I was just wanting to know if that was normal for non checked top links, or I have have a problem with my setup (again not the cylenders fault as far as I know).
so far from things i tried to today, it stays the length you set it at even if it is weighted. Is your relief valve closed all the way on the tractor? I have a relief valve on the back where the rear remotes are and i had it open at first and noticed the same thing. didnt know it was open. I closed it and all is good
   / Fit Rite Hydraulic Top Link Kit- Installed Today #8
At the risk of sounding really stupid, what bypass valve? I have a JD4300. Maybe I really missed something here and have been living with this when it could be much better.
Thanks for you help.
i dont know any more than you do really. im new with this stuff. Ill go get some video of the valave im talking about. i would take picture but i havent seen my **** phone since this morning.
2012 FORD F-550 SUPER DUTY XLT SERVICE TRUCK (A51406)
2012 FORD F-550...
2021 MACK GRANITE TRI AXLE DUMP TRUCK (A52576)
2021 MACK GRANITE...
2019 Fontaine EQ1 Hydraulic Equalizing Spreader (A52377)
2019 Fontaine EQ1...
UNUSED AGT SAWMILL MODEL - YC32G (A51248)
UNUSED AGT SAWMILL...
(2) UNUSED 7000# DROP AXLES W/ BRAKES (A51247)
(2) UNUSED 7000#...
