Fitting nomenclature.....
   / Fitting nomenclature..... #1
mrcaptainbob
Platinum Member
Jackson County, Michigan
Bolens HT-20
I don't know what they are called. Hydraulic fittings that would have male/female pipe thread on one end and have threads that end in a sort of cone shape on the other. Kind of like typical gas stove connector fittings. What are these things called? Oh yeah... and what are the threads on that coned end called? Not SAE, not m/fpt.....
   / Fitting nomenclature..... #4
The guide from discount hydraulic hose is super helpful. I referred to that a bunch when I was doing work on my tractor.
It sounds like you are describing a fitting that has NPTF on one end and JIC 37 on the other.
The other type of fitting that is pretty common is ORB (O Ring Boss).
This page probably has the connector you need on it. JIC 37° Hydraulic Tube Fittings > Discount Hydraulic Hose.com
2011 PETERBILT 384 TANDEM AXLE TANKER TRUCK AND TANKER TRAILERS (A54607)
2011 PETERBILT 384...
Takeuchi Skid Steer (A52377)
Takeuchi Skid...
2008 Ford F-450 Crew Cab Service Truck (A52377)
2008 Ford F-450...
2018 Toro Workman GTX Electric Utility Cart (A54811)
2018 Toro Workman...
2017 Ford Fusion Hybrid Sedan (A53424)
2017 Ford Fusion...
