Fixed my "PTO only works in Reverse Safety Mode" issue
   / Fixed my "PTO only works in Reverse Safety Mode" issue #1
y2kvfr
Berkshires, MA
Mahindra 2538 HST
Hi!
I bought my 1554GT used. From 'my' day 1, the PTO would engage then stop if in the normal (forward mowing) key position. I've always had to switch it to reverse mode and hit the button.
Today, while changing the oil, I was poking around, cleaning debris out from the undercarriage and saw a wire _*REALLY*_ close to the disc brake. It turns out, it is the reverse indicator wire. The brake had worn down the insulation and it would short (thereby indicating 'reverse') to the disc.
I clipped the bad section out, replaced it with a longer wire and put a loom over it. I then zip-tied the loom out of harms way.
Oil change done, mower now works in 'normal'.
I thought I'd post up in the hope that this will help someone in the same situation.
It was really poor routing of the wire.
-travis
   / Fixed my "PTO only works in Reverse Safety Mode" issue #2
Thanks for the help. I'll check the wire out on my 2554 to make sure it isn't routed the same way.
I wish I had the where-with-all to take pictures before going headlong into it. (It's not like I don't have a camera on my hip at all times too!)
2014 Ford Explorer AWD SUV (A50324)
2014 Ford Explorer...
2016 Ford Explorer...
2017 CATERPILLAR 259D SKID STEER (A51242)
2017 CATERPILLAR...
2013 MACK ELITE LEU633 GARBAGE TRUCK (A51243)
2013 MACK ELITE...
2018 Ford Escape SE AWD SUV (A50324)
2018 Ford Escape...
2020 KUBOTA RTV...
