Fixing a hydraulic leak - DIY?
Status
Not open for further replies.
   / Fixing a hydraulic leak - DIY? #1
RobA
Platinum Member
Chester County, SE PA
Kubota L5030 HST
I was clearing more of my acreage today using the grapple to pick up debris left over from when we had it timbered. I was just about done for the day when I saw another log to put on the burn pile. Then I noticed what looked like a white dust puffing upwards from in front of the hood. Then the dust turned into a spray. Hydraulic fluid was spraying from the grapple. I was in a hurry to get home so I put the tractor away without seeing exactly where the leak was coming from.
I assume the leak is from a fitting or the hose (some branches may have poked the hose?). If it is a loose fitting do I just need to tighten it? If it is a hose can I just disconnect it and get a new one and replace it myself?
   / Fixing a hydraulic leak - DIY? #2
</font><font color="blue" class="small">( If it is a loose fitting do I just need to tighten it? If it is a hose can I just disconnect it and get a new one and replace it myself? )</font>
Yes and yes.
All it takes is the right size wrenches. Make sure there is no pressure in the line by cycling the loader valve first.
Status
3110 (A46502)
3110 (A46502)
New Wolverine Auger 12'' & 18'' Bits (A48289)
New Wolverine...
John Deere 5 Bottom Semi-Mounted Plow (A49339)
John Deere 5...
3011 (A49339)
3011 (A49339)
2016 Case-IH 620 QuadTrac (A49339)
2016 Case-IH 620...
26x25 Rim (A49339)
26x25 Rim (A49339)
