Hi,
Thought I would post a new thread on a project to fix up my old backhoe.
"Thingy" spur'ed this with his comments, so if it's a waste of bandwidth - blame him too!
Actually, if there are things done wrong - feel free to pipe in and share the correct methods. That's how I learn - screwing up then fixing it up!
Thingy,
I don't have much more than a clue. Didn't stay at Holiday Inn last night, but took a class at the Tech School.
How about I tell you what I was doing, you can tell me how I did.
Fixing cracks on a backhoe. After taking it all apart, it "feels" like the hoe was in a conflict with an overpass at one point. Could be just 43 years of wear and tear, but...
When repairing cracks, I try to have the work in a normal flat position. Makes it easier to pour the heat in. Grind a new spot for the ground clamp. PRessure wash the grease and oil off. Wire brush off the rust and what ever paint there may be. Grind the crack. 4 1/2" grinder or carbide cutter in an air grinder. Cracks I am fixing are ones that are all the way thru. Many have been welded before. Some by trained monkeys with a stick welder. (And I offer appologies for the comparison to monkey's everywhere.) I dry out the cracks with compressed air and spray them down with brake cleaner. If it is more than 10 ga, I will give it some heat O/A rosebud. Also give heat if there is a lot of grease and oil.
Here's the machine in use.
Here's the hoe as bought.
Here's some of the "issues"
Cylinder to swing post.
Top pivot point of swing post
Here's some pictures of the dipper stick.
Some grinding of the cracks. Still need to remove the barnicle. Look close and see there is still slag in the weld from not chipping between passes.
Under the barnicle.
If there is interest, I can post more. There are a lot more cracks.
jb
thingy said:Well,if you just spent the day fixing cracks with a short circuiting mig,,I shouldn't have to tell you the dos and don'ts,,,
{But you do! }
[if you fixed them],
{Don't know if I did!}
sounds like you might know as much or more than me about it.
{No where close}
Why don't you tell us some dos and don't when it comes to mig welding? Cause,there certainly are some dos and don'ts,,,and most of your backyard type wire burners,don't have a clue about them,or care,,,,,your turn,,,,thingy
Thingy,
Under the barnicle.
jb
