Just picked this up yesterday from a junk yard, but I can't find a badge on it anywhere with a brand or model number. It has a John Deere belt on it though.
Any ideas from the flail masters out there? I can get other pictures if it would help.
thanks
Aaron
Uploaded with
ImageShack.us
I am almost positive it is a mott mower: remove the belt guard and look there for an ID tag or on the mower hood at the corners.
The mott mowers are the ones sent to junk yards because the Mott Mower company is no longer in business thanks to ALAMO to kill thier competion
Dont sell it or scrap it as you can still buy mower knives, knive grinders, bearings, rotors, belts, pulleys from flailmaster.com
The knives are not that expensive and last a long time, we are still using 30 plus year old knives on our matthews flail mower.
You have the safest type of mower you can own as far as being able to mow with no worries about hitting and throwing anything.
Did you happen to see any flail mowers with gas engines that were still in one piece?
The fastest way to mow with a flail mower is mowing in a circle as there is no braking or stopping to turn and you simply overlap if the grass is tall-but the slower you move forward whole mowing the knives cut faster and finer with very little grass showing and its is gone in a few days- if you have sone grass left you can go over it again with lttle effort and chop it up.
The full width roller eliminates scalping too. just be sure to lock the implement control valve closed to avoid it dropping unexpectedly in float while you mow.
You have a forever mower my friend and dont let it go!!! **** you dont even have clean it unless you have to change bearings because they run so clean with no grass build up because of the suction created by the knife rotor.
