Flail Mower Flail Mower vs Finish Mower or Bush Hog
   / Flail Mower vs Finish Mower or Bush Hog #1
Mosey
Veteran Member
Conifer, Colorado
2000 New Holland TC29D with 7308 FEL, and top & tilt. 1950 John Deere B. 1940 Farmall A.
Does anyone here have experience with flail mowers? I realize they won’t replace a bush hog, but I am curious about what they will do and how they compare to a bush hog and a finish mower.
My questions are:
1) How does the cut compare to a finish mower?
2) Do they handle taller grass or do you have to keep the grass mowed regularly? For example, can I cut 4’ grass with one?
3) Do they typically cost more or less than a bush hog?
4) What can I do with a flail mower that I can't do with a finish mower? For example, I saw an add for one that is "offsetable" which would be handy.
5) What can I do with a finish mower that I can't do with a flail mower?
6) Can I go as fast with a flail mower as I can with a finish mower?
7) What are some pro and cons of flail mowers that anyone can think of?
Thanks!
   / Flail Mower vs Finish Mower or Bush Hog #2
The only thing I know about flail mowers is what my friend told me. He had one to use on his pastures, and he said it was a maintenance nightmare. He said he had to constantly work on it. He finally just stoped using it and bought a brush hog.
Rich
"What a long strange trip it's been."
   / Flail Mower vs Finish Mower or Bush Hog #3
Flails can be great - if your place is not rocky. In answer to your questions:
1) Not quite as smooth as finish mower, better than rotary.
2) The handle taller grass better than a finisher, just need to slow down.
3) Depends on the quality - there's a wide range from less to much more.
4) Offset is possible ($$ if variable), follows uneven ground a little better, will grind orchard prunings & small brush better than a finisher or rotary.
5) Finish mower leaves the most uniform cut. Blades for finisher are cheaper (depending on flail model)
6) Yes mowing speed is similar.
7) Pro - Makes woody brush disappear - compact unit - good ground compliance. Con - the better ones have heavier forged blades - work great but are expensive to replace and don't seem to tolerate rocks as well as other mowers. High speed, high inertia means more bearing maintenance. Failed bearings can mean shaft replacement (big $$).
   / Flail Mower vs Finish Mower or Bush Hog #4
I had a Ford flail, sorry, can't remember the model number. it was a very good machine, and produced an excellent cut. Late last fall, I bought a JD 25A flail. I have not mowed with it yet, but have had it on the tractor and everything is fine with it.
1) As good or better
2) I've seen a city owned tractor with right and left side flails, and one on the rear mow 5' grass, weeds and cattails.
3) More than a brush hog. The 25A's run about $3500 new.
4) Offset, as you mentioned, is a great advantage.
5) Throw rocks.
6) Yes, JD manual claims mow up to 7 mph.
7) Pro: In our operation, mowing 250+- subdivision lots in a residential setting, safety is utmost. Launching rocks and other items is less than desireable for us. Easy to manuver around lot stakes, power poles, pad mount transformers, ect., offset makes trimmimg a lot easier. Flail knives are a lot less weight to handle when changing blades. I've changes a set of flails on the Ford, 72 blades, in 20 minutes with an air ratchet.
Con: Cost of a new unit.
Check out this link,<A target="_blank" HREF=http://www.flail-master.com>FlailMaster</A> has an extensive line of replacement parts for many different manufactures mowers, and with better prices than OEM dealer.
For the average home owner, the flails are spendy compaired to finish and rotary mowers. For our business use, I can easily justify the added expense, when safety is concerned. As long as they are used properly, and cared for, they provide many years of service at a reasonable price.
Paul
   / Flail Mower vs Finish Mower or Bush Hog #5
Danny,
<A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showthreaded.pl?Cat=&Board=implement&Number=63517&Search=true&Forum=All_Forums&Words=Flail&Match=Entire%20Phrase&Searchpage=1&Limit=50&Old=allposts&Main=62726>Here's an older post on rotary & some flail...</A>
   / Flail Mower vs Finish Mower or Bush Hog #6
My dad had a flail mower on his old Farmall. The only problem he ever had with it was the broken flails. He used to replace about 10-15 each spring. Not that bad considering he was mowing a junk yard. The one problem I could see with the setup was noise. Made a LOT of racket.
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A51039)
Kubota BX2680...
2019 MMDI 14ft T/A Utility Trailer w/ Fuel Tank (A48082)
2019 MMDI 14ft T/A...
RoGator 844 sprayer (A50490)
RoGator 844...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
LIGHT BAR AND WIRING (A50854)
LIGHT BAR AND...
2012 GENIE S-60X MANLIFT (A50854)
2012 GENIE S-60X...
