Flat Repair
   / Flat Repair #1
ch1ch2
Veteran Member
DFW, TX
IH 584, NH TC33DA, NH TN95A
I have three tractors all of which have had flats. There are different types of thorn trees on my property.
I have used the green stuff and the purple stuff. I have plugged and I have patched. One tractor has tube tires. I would prefer to run water ballast in the tires if I can.
What do all of you experienced guys (and gals) recommend?
   / Flat Repair #2
down here in florida i have same proeblem with flats while bush hogging in the woods...i had great luck so far with tubes..a shop ordered heavy duty tubes for me so far no issues
   / Flat Repair #3
I run tubes as well, ad in thorny areas, my mowers have boots inthe tires to help protect the tubes.
AMG M 35 A2 C drop side 2 1/2 ton 6 x 6 truck (A50323)
AMG M 35 A2 C drop...
2013 FREIGHTLINER CASCADIA (A50854)
2013 FREIGHTLINER...
AMG M 35A2C drop side 2 1/2 ton 6 x 6 (A50323)
AMG M 35A2C drop...
2009 Lee-Boy 8510HD Conveyer Feed paver (A51039)
2009 Lee-Boy...
1,000 Gallon Horizontal Fuel Storage Tank with Pump - Farm or Construction Ready (A51039)
1,000 Gallon...
2006 IC PB30500 School Bus (A50323)
2006 IC PB30500...
