wjmst
So, I'm at work yesterday getting ready to leave and my coworker tells me I have a flat tire. I go out and take a look at it and sure enough it is completely flat.
Another coworker says he has a can of fix-a-flat in his car. I'm not too keen on using the stuff, but it also just starting raining, so I figured I would give it a try. Well, I don't know how long it was in his car, but the can didn't work. Period. The stuff wouldn't come out.
I abandoned that operation and decided to just pump the tire up and see what happens. I always carry a small portable compressor in the car for these situations (along with some rags, tools, and other misc items). The tire pumps up for about ten minutes. I shut the pump off and can hear the hissing air out of the hole. So time to get the spare and jack out.
For some reason the jack would not collapse enough to fit under the car. Thankfully, another guy grabbed his jack. He just didn't have a handle for it and of course my jack handle didn't fit his jack. So we used a screwdriver to twist the jack up and put the spare tire on. Of course we had to kick the tire several times to loosen it from the car.
I put some air in the spare tire. I could only inflate it up to 40psi not the 60 recommended on the sidewall, but it seemed fine for my trip home. Finally, since I have a Subaru, I needed to disengage the AWD. So I popped the hood and grabbed a spare fuse to take it back to the fuse box in the cabin and insert it into the AWD override slot. Thirty minutes later I was pulling into my driveway.
Always a fun time in the rain. At least I was in a parking lot with some helpers around. I'll get the tire repaired this weekend and check out the jack before putting everything back in the car.
I'm sure many of you have experienced similar situations. What do you carry in your car to ease the burden of a tire change? Is there a can of sealant that actually works, is safe, and doesn't mess up the tire monitor sensors? I use slime in my tractors and other equipment around the house. It seems to work ok but those are all slow moving machines.
