Flats I hate Flats....
   / Flats I hate Flats.... #1
jmichael
I have owned my BX 23 dfor a little over a year now.. In this time I have had to replace 2 tires and fix about 15 flats. Granted I have been working my BX23 very hard to say the least but I would like to put an end to my flats.. I was thinking that I could drill a hole in the tire itself and fill it with cement. then patch the hole in some way when I am done.. I was wondering if anyone else had ever done this before.. I know I can send them out to be made solid but I have to wait 3 weeks for them to come back and it will cost as much if not more then new tires. Any suggestions?
   / Flats I hate Flats.... #3
Cement ??? You're kidding right? You can get them foam filled which will solve your problem.
   / Flats I hate Flats.... #4
   / Flats I hate Flats.... #5
I just added 32 oz of the green slime tire sealer to each of my rear tires last night cause one of them had a small hole. They say it will seal a hole up to 1/4 inch. On sale at Harbor Freight stores for $9.99 through the end of the month.
   / Flats I hate Flats.... #6
   / Flats I hate Flats.... #7
I had mine foam filled. The tractor was down over a weekend. I can't imagine why it would take 3 weeks. Call some tire dealers. It was expensive but no flats.
   / Flats I hate Flats.... #8
   / Flats I hate Flats.... #9
On my little BCS, I had the tires foam filled, and that has saved me endless aggravation. Find a tire shop that does it in-house. The one near me that does usually waits for a few jobs to come in, and does them all at once, to save clean-up time.
On the big tractor, we've just got (Kub L-39: yeeha!)/forums/images/graemlins/cool.gif, filling is not recommended for either front or rears, so I ordered 5 gallons of Gempler's Ultraseal Bulletproof-grade tire sealant. They say it's good for sealing-up holes up to 1/2"., and that it's good for the life of the tire.
But the good news for me is that, despite running the L-39 through some Hawthorn patches, I haven't developed any holes or leaks yet, so I've put-off actually using the slime so far (pushing my luck as usual, but I'd rather the seat time...)
The L-39 actually needs about 4 gallons of the stuff to do all the tires (but the 5-gal pail worked out cheaper for me, and I'll be sure to need the other gallon for various other tires). Your little BX would probably need half that or less. The Gempler's folks will look up the rate for you if you give them your tire size. Good luck...
-otus
   / Flats I hate Flats.... #10
-otus
2011 Ford Escape XLT SUV (A54815)
2011 Ford Escape...
2005 FONTAINE 48 FOOT FLATBED (A53843)
2005 FONTAINE 48...
2010 GLOBAL TRI AXLE HAUL TRAILER (A55745)
2010 GLOBAL TRI...
2025 GIYI VR66 66in Vibratory Roller Skid Steer Attachment (A53421)
2025 GIYI VR66...
2016 Winco Standby PSS8B Generator (A54865)
2016 Winco Standby...
2019 KUBOTA SVL95-2S SKID STEER (A52707)
2019 KUBOTA...
