Flats
   / Flats #1
RedRocker
Veteran Member
Bowie TX
Kioti CK30 HST, dual remotes, FEL.
Got my first flat, nice big thorn in the front tire. I used this to plug it. These are for motorcycles, but have worked great for my quad and seem to be workin well on the tractor. I would think they'd work with filled tires too. I've got the model at the bottom of the page with the zipper pouch and gun.
   / Flats #2
That is interesting, because those plugs look like the first tire plugs that came on the market in the '50s; i.e., mushroom heads on them. But the early ones did not work very well, and I didn't know they even still made that style. The soft rubber, sticky, "cord" types are the only ones I've seen in a long time. The early mushroom types would sling out at higher speeds causing a blowout, so I wouldn't have expected them to be used on a motorcycle tire, but would probably work just fine on a tractor. The new ones must be made with a different composition.
   / Flats #3
Bird in the 70s we used a pneumatic gun to drive the same type of mushroom head rubber plugs into auto tires needing repair. As I recall they did a pretty decent job of stopping the leak. I don't know if they are still used today or not.
Since we don't have our tires filled with liquid ballast we are a firm believer of liquid tire sealants. We haven't had a flat since we treated our tires with Multi-Seal and we have lots of thorns on the property.
   / Flats
These don't use glue either, it comes with oil to facilitate the installation. I put one in my quad tire over a year ago and it's still working.
2015 Peterbilt 320 Garbage Truck (A52377)
2015 Peterbilt 320...
2013 MAXEY TRAILER MFG UTILITY TRAILER (A53843)
2013 MAXEY TRAILER...
HarbinGer V3 Plus S/A Towable Light Tower (A52377)
HarbinGer V3 Plus...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51691)
2015 Toro Multi...
2016 Ford F350 - Butler Bale Bed - 4WD - 125k Miles (A53473)
2016 Ford F350 -...
2013 Ford Transit Connect Van (A52377)
2013 Ford Transit...
