float detent on joystick for loader HELP
   / float detent on joystick for loader HELP #1
JoeL4330
Platinum Member
Harpers Ferry WV
Kubota L4330, 6 rear remotes
Bota L4330: joystick will no longer stay in float detent position...suggestions?
   / float detent on joystick for loader HELP #2
That's just a (spring loaded) ball detent or something like that. If it's internal to the valve, that could be a hassle (unless your tractor is still in Warranty). Unless you're mechanically inclined and somewhat familar with hydraulics, I suggest you leave that to your Dealer.
If you follow the joy stick down to the valve, you may see an external detent. Might be a pretty easy adjustment then.
Good luck!
2009 Yamaha Golf Cart (A52377)
2009 Yamaha Golf...
2019 Chevrolet Cruze Sedan (A53424)
2019 Chevrolet...
Pair 2 new 10' pallet fork extensions (A53421)
Pair 2 new 10'...
2001 Freightliner E-One Pumper (A52377)
2001 Freightliner...
