Float getting stuck
   / Float getting stuck #1
Donsyl
Central Arkansas
Cub Cadet 1811 \and a cub cadet 149
Ok ive been trying to figure this out for a while. I have a cub cadet 1811 and every now and then it sputters and i finally figured out it is the float getting stuck....what is the proper repair for this? is it a carb rebuild kit? or can i just get a new float pin? thanks Don
   / Float getting stuck #2
I was working on a B&S recently and I had to push and pull the float pin in and out until it worked free. Then I did the same on float so there was no binding. That fixed the flooding but there was more crud in the pilot tube that a few hours of soaking in lacquer thinner softened and cleaned.
thanks Jim i appreciate the advice......Don
   / Float getting stuck #4
did u ever figure out your float problem,i have some advice for u if u didnt
   / Float getting stuck #6
absoulutly it could be dirt, also does he use stabilizer off season,could be getting all gummed up,but i would start by spraying a little carb cleaner in it.
theres also other options depending more on the details of the care given to the tractor.keep bringing them
UNUSED JCT SKID STEER QUCK ATTACH 72" BRUSH CUTTER (A51244)
UNUSED JCT SKID...
2011 PETERBILT 367 T/A DAYCAB ROAD TRACTOR (A51243)
2011 PETERBILT 367...
Woods LR72 72" 3pt Rake (A50774)
Woods LR72 72" 3pt...
UNUSED FUTURE MINI SKID STEER HOLLOW WOOD GRABBER (A51244)
UNUSED FUTURE MINI...
2011 Chevrolet Malibu Sedan (A50324)
2011 Chevrolet...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
