Flow divider PTO control valve
   / Flow divider PTO control valve #1
okfarmguy
Marlow, OK
1175 Case
I have a Case 1175, the PTO clutch pack was removed and taken to a dealer to have the clutch pack rebuilt. Upon reinstallation the PTO, three point lift, or the remotes will not work. With closer inspection it was discovered there is 3000# pressure at flow divider and no pressure exiting the flow divider. Removed the flow divider and rebuilt all portions with new o-rings, cleaned and lubricated all parts, used Scotch-Brite to insure there were no rough spots to hang, and replaced flow divider. Still, I have no pressure going thru the flow divider or the pressure release valve (obviously). As the lines from the pump were the only ones removed during disassembly, I cannot reason what could have happened to the flow divider, why it suddenly quit working, or why after disassembly and inspection it will not work again. Any information on these problems will be appreciated.
   / Flow divider PTO control valve #2
Could 2 hoses have been switched? That's quite a mystery, good luck with it. Let us know how it works out.
2008 Bobcat S250 Skidloader (RUNS) (A50774)
2008 Bobcat S250...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2022 Ford F-550 Cab and Chassis Truck (A50323)
2022 Ford F-550...
2018 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
2009 Kubota RTV1140 (A50121)
2009 Kubota...
2016 Big Tex 7'x16' Trailer (A50121)
2016 Big Tex...
