fluid in tires
   / fluid in tires #1
traderman55
northeast mississippi
mitsubishi mt372
i have a b6200 with 16 in rear tires.they have tubes in them .i am wanting to put fluid in them for weight .how many gallons of anti freeze should i put in each tire ,and how many gallons of water should i put in each tire??? thanks
   / fluid in tires #2
i have a b6200 with 16 in rear tires.how many gallons of anti freeze should i put in each tire
What size 16 inch tire are you running and why not us windshield washer fluid? It is still a little toxic but not nearly as bad as antifreeze. And it should be a lot less$ for the same weight.
   / fluid in tires #3
How cold does it get there as an average day-night reading?
larry
   / fluid in tires #4
In Alabama the dealer recommends 1 Gal for the rear tire on my L2800. It's been OK for five years so far.
   / fluid in tires
they are 750x16 i need to know how many gallons of fluid they will hold .anti freeze not really that important .i will deal with that this winter.just tell me how many gallons of fluid i can put in an the air pressure in them thanks
   / fluid in tires #6
I think TSC has a fluid fill fitting to let you fill them with a hose and bleed off air. Gemplers does for sure. ... If those are AGs they should hold about 10G filled to the top of the rim at 12 oclock position. Use a pressure that makes them look right - tread touching down full width. You could probably use water year round where you are. I dont drain mine til well into december.
larry
   / fluid in tires
thanks for the info.. i have a fitting to put in the fluid .. bought it at t.s.c. just need a little more traction when plowing garden ...
14ft Bi-Parting Iron Gate (Cow Design) (A51573)
14ft Bi-Parting...
Starcraft Starlite 22ft Travel Trailer (A51694)
Starcraft Starlite...
2013 FORD F550 SHUTTLE BUS (A52576)
2013 FORD F550...
Laymor SM450-ST Sweeper (A51573)
Laymor SM450-ST...
1/4 '' Wolverine Universal Quick Attach Mount Plate (A51573)
1/4 '' Wolverine...
2015 Ford E350 Cutaway Van (A52377)
2015 Ford E350...
