flushing cooling system
   / flushing cooling system #1
cmyoung2
Platinum Member
North west NC mountains
BCS 850, Kubota BX2230 w/FEL, mid mount mower, 41" tiller Kubota L3600 w/4-1FEL, Farmi winch
Finally get time to replace water pump and hoses on my 99 F250 V-10. Know the system needs cleaning, is one product any better than the rest? Prestone is handy, but I have time to look at other stuff. And what would be the best coolant to put back in? OEM stuff has lasted 220k+, hope the replacement will do as well. Replacing drive belt and belt tensioner at the same time.
   / flushing cooling system #2
That's a long time to leave the same coolant in. If everything looks good, as in radiator doesn't looked clogged up or gummed up, I'd just flush it with clean water. What antifreeze? What does the owners manual say? Some say to use a special antifreeze, some don't.
   / flushing cooling system #3
I'd poke around on a Ford or V10 specific forum for advice. I found an excellent step by step for a system flush on Dieselstop for the 7.3 Powerstroke I just sold.
   / flushing cooling system #4
I flush with clear water- with so many hoses/water passages I worry about getting all of a caustic cleaner out.
RANT: New Asian vehicles require special coolant that not only is expensive and hard to find, but usually only can be found pre-diluted, which means that any clear
water left in the system from a flush further dilutes the coolant.
   / flushing cooling system #5
Sent the wife's Hummer out for a coolant flush and Tstat replace on Friday..~$200...Well worth it for me.:D
   / flushing cooling system #6
Thats not a bad price when you figure in the parts cost.
Was the T Stat bad? I have never had one go bad on a vehicle but replaced a few after 120,000 miles. Now boats are another thing. I can't keep a T Stat more than 3 season. The silt buggers them up quickly.
Chris
   / flushing cooling system #7
One function of coolant is to prevent corrosion from dissimilar metals. I would replace much more often than 15 years.
   / flushing cooling system #8
Chris
The truck was throwing a low temp code when temps got into the single digits over the last year or 2...other than that, never mis-behaved temp wise..Figured since it was a 2006, it was beyond time for a flush and get the tstat done--The placement of which is not fun so had both done at the same time. Thought price was more than fair..That's with all recommended additives etc...That's the first thermostat I've replaced since I can't remember when. No complaints here.
   / flushing cooling system #9
Chris
Obviously not heat exchanger cooled, but then in a fresh water area no one spends the money for heat exchanger systems.
And of course, even exchanger systems can have "issues" with the raw-water side, as the government found out:
https://idea.library.drexel.edu/islandora/object/idea:1347/datastream/OBJ/view
   / flushing cooling system #10
I used to do a lot more "wrenching" on vehicles than I do now; water pumps, in-tank electric fuel pumps, starters & alternators, that sort of stuff.
All of it is pretty simple to do, *IF* you can get to the stuff, which is the problem now. Too much machinery crammed into too little space.
2003 VIKING  CEMENT MIXING TRAILER (A45333)
2003 VIKING...
2003 Ford F-450 Versalift Bucket Truck (A45336)
2003 Ford F-450...
1998 Express Trailer 14ft T/A Concession Trailer (A46683)
1998 Express...
2018 Ford F-150 Service Truck (A46683)
2018 Ford F-150...
2034 (A46502)
2034 (A46502)
Hunter TCX620 Tire Changer (A46683)
Hunter TCX620 Tire...
