Food plots
   / Food plots #1
EddieWalker
Epic Contributor
Tyler, Texas
Several, all used and abused.
I'm looking for some advice on building a food plot.
Currently my only open area, about 30 acres, is covered in native vegitation and small trees. I'm brush hogging four, 2 acre, areas I plan to plant for hunting season.
Would if be better to buy a disc harrow or a tiller? Money is always a concern, but so is the result.
   / Food plots #2
I use a single bottom plow and disc's. it's cheaper than a tiller.
now you could look at a spring toothed harrow and disc. i would like to have a spring toothed harrow or field cultivator or as some call them all purpose plows .
i just can't justify a tiller for the price. i think i have around $450 in my disc's and plow. now a tiller is a grand!
you can find used stuff cheap if you look. i bought my 14 " single moldboard for $100 in a auction.cheaper than the 350 spring tooth harrow i found ( i didnt buy it).
the disc and plow method is a little more time consuming but look at it like your spending more time having fun! /forums/images/graemlins/grin.gif
   / Food plots #3
We plant about an acre south of Fredericksburg, TX every year. That ground is really hard when it is dry. For several years we pulled a tractor down there and tilled it each year. Last year, the landowner offered to let us use his 8N pulling a disc. That worked just as well as the tiller had. However, the soil was fairly easy to turn with the disc probably because it had been tilled for several years.
2023 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2023 PETERBILT 579...
John Deere (A50322)
John Deere (A50322)
Toro 30495 Groundsmaster 7200 72in Zero Turn Mower (A48082)
Toro 30495...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
2022 KUBOTA KX040-4 EXCAVATOR (A51242)
2022 KUBOTA...
SCAN FOR HAULING AND FINANCING INFORMATION (A51242)
SCAN FOR HAULING...
